postgresq syntax error
in the fil:
ext\ai-laravel\lib\custom\setup\CustomerRemoveConstraints.php
error syntax:
the correct syntax :
thank you
in the fil:
error syntax:
ALTER TABLE "users_address" DROP FOREIGN KEY "fk_lvuad_pid"
ALTER TABLE users_address DROP CONSTRAINT fk_lvuad_pid RESTRICT;
Re: postgresq syntax error
Thank you for pointing out. Can you please create an issue in the https://github.com/aimeos/ai-laravel Github repository?
