Integrating PayPro with Aimeos
For the connection we have used Omnipay for the integration. Can we use the current integration and adjust it for PayPro?
Documentation for Paypro API can be found here:
https://www.paypro.nl/developers/docs/p ... uickstart/
If it is possible then where to change the code ? or it already not needed for that (if we can do it from admin panel). ? please let me know. ASAP
we are using aimeos 19 version and laravel 7 in linux OS.
Re: Integrating PayPro with Aimeos
There's already an Omnipay driver for PayPro but only for Omnipay v2:
https://github.com/payproNL/omnipay-paypro
It might work with 2019.10 but keep in mind that this version isn't supported any more without ELTS support.
Well i got it. But should a composer install will do the job ? or there is additional requirements to make it work with the system. If it is then what are the steps and what are the required process to do the changes. Please can you provide a details demo. Thanks
Here's the documentation how to configure it in Aimeos after installing it via composer:
https://aimeos.org/docs/latest/manual/s ... ay-generic
Read the Omnipay docs and ask in an Omnipay forum what must be done to update the driver.
