CHANGE THE LOGO
CHANGE THE LOGO
HI; please i want just know how to change the default logo aimeos
Re: CHANGE THE LOGO
What host application do you use? Laravel?
Thenk, you can change the logo in the ./resources/views/app.blade.php template.
Re: CHANGE THE LOGO
First Thank you for the quick response.
yes i use the laravel framework.
in the ./resources/views/app.blade.php template, i see this in line 34:
<img src="https://aimeos.org/fileadmin/template/icons/logo.png" height="30" title="Aimeos Logo">
but when i try to change the logo, it don't work. at the bottom of the app.blade.php file is the new logo called samba.png
what should I do so that the logo is visible by the application ?
- Capture.PNG (221.03 KiB) Viewed 1410 times
