Use arabic language with latin numbers
windows 10: 64
PostgreSQL 9.6.15
Laravel Framework 8.37.0
PHP 7.4.16
"php": "^7.3|^8.0",
"aimeos/aimeos-laravel": "~2021.04",
by default when I choose the arabic language, aimeos displays the numerals in arabic too, but it is arabic numeral is not used by all arabic countries (٠١ ٢ ٣ ٤ ٥ ٦ ٧ ٨ ٩ ), it uses latin numbers (123 ..).
i want to use arabic language and latin numbers (123 ..)
thank you
windows 10: 64
PostgreSQL 9.6.15
PHP 7.4.16
"php": "^7.3|^8.0",
thank you
- nombre.png (8.39 KiB) Viewed 1932 times
Re: Use arabic language with latin numbers
This is automatically done by the browser and the option to use latin number seems to be to change the templates and define
explicitely for all numbers:
https://www.w3.org/International/articl ... di-markup/
dir="ltr"
I think this can not solve the problem .
Because when i type: ===> 9999.99
But when i type: ===> ٩٩٩٩.٩٩
i want to acces to the function number(. where is ?
thank you
I think this
dir="ltr"
$priceItem->getValue() ;
But when i type:
$this->number( $priceItem->getValue(), $priceItem->getPrecision() ), "$currency" )
thank you
The number view helper is available here:
https://github.com/aimeos/aimeos-core/b ... Locale.php
There's also another one available:
https://github.com/aimeos/aimeos-core/b ... andard.php
You can change it overwriting this method:
https://github.com/aimeos/aimeos-larave ... #L161-L170
And then in a Laravel service provider:
https://github.com/aimeos/aimeos-larave ... hp#L92-L94
We've simplified that in aimeos/aimeos-laravel:dev-master and added a new config setting for the ./config/shop.php file:
If you checkout the master version, you can change the number formatter by adding:
Can you check if that works for you?
'num_formatter' => 'Locale', // locale based number formatter (alternative: "Standard")
'num_formatter' => 'Standard',
I checked this parameter it working perfectly!
Thank you
Thank you
