Create Product Attribute
marlonsamot
Post by marlonsamot » 10 May 2021, 03:04
Hi devs, please help me with this.
I want to create a attribute of a product in controller. Still, i don't get it how it works
Re: Create Product Attribute
Post by aimeos » 12 May 2021, 06:47
Use the product and attribute manager:
$attrManager = \Aimeos\MShop::create( $context, 'attribute' );
$manager = \Aimeos\MShop::create( $context, 'product' );
$attrItem = $attrManager->create()->setCode( 'value' )->setType( 'test' );
$prodItem = $manager->create()->setCode( 'test' );
$listItem = $manager->createListItem();
$prodItem->addListItem( 'attribute', $listItem, $attrItem );
$manager->save( $prodItem );
This creates a new attribute item and attaches it to a new product item.
marlonsamot
Post by marlonsamot » 13 May 2021, 13:54
Which part of the code to identify on what product do i add a attribute :?: :?:
for example,
$product_id = 15;
this key of product id i need to add a attribute
Post by aimeos » 13 May 2021, 15:33
Use e.g.
$manager->get( $product_id, ['attribute', 'media', 'price', 'text'] );
marlonsamot
Post by marlonsamot » 14 May 2021, 11:05
I use this code
But it appears
https://prnt.sc/12x5zye
Post by aimeos » 15 May 2021, 10:14
You have to use the product item you are fetching and not create another one afterwards. Use this code instead:
        $prodItem = $manager->get( $product_id, ['attribute', 'media', 'price', 'text'] );
Note: This code will fail when running twice because the attribute and listitem will be created again and you will receive a duplicate error from the database.
marlonsamot
Post by marlonsamot » 17 May 2021, 12:56
Thank you for this, it works :o :o :o .
Last question how about to validate if attribute exist ? just add it on a product only.
Post by aimeos » 19 May 2021, 07:47
Use something like this:
$attrMap = [];
foreach( $prodItem->getListItems( 'attribute', null, null, false ) as $listItem ) {
	if( $refItem = $listItem->getRefItem() ) {
		$attrMap[$refItem->getType()][$refItem->getCode()] = $listItem;
if( !isset( $attrMap['test']['value'] ) ) {
