rewrite or new template
JackDarkWeb
Post by JackDarkWeb » 10 May 2021, 05:49
Hello community
This is my first day with aimeos in laravel. After the installation and configuration and in my browser everything works perfectly. But my project that I want to work on has a completely different homepage than the default page of aimeos. As usual with laravel I did everything in the views folder which is in the resources folder.
How can I proceed ? please help me
Re: rewrite or new template
Post by aimeos » 12 May 2021, 06:52
The base HTML template is in the ./resources/views/app.blade.php file. Then, you should read how to adapt the Aimeos HTML client templates:
https://aimeos.org/docs/latest/frontend ... templates/
On the homepage, usually the catalog/home component is used:
https://github.com/aimeos/ai-client-htm ... talog/home
You can add or remove components on the home page by configuration:
https://github.com/aimeos/aimeos-larave ... op.php#L31
JackDarkWeb
Post by JackDarkWeb » 13 May 2021, 13:04
I am very happy for your answer and I thank you. I made some text changes in the file(ai-client-html/client/html/templates/catalog/home/body-standard.php/) but I don't see the change on the screen and also I tried to clear the caches and views.
Post by aimeos » 13 May 2021, 15:30
To clear the Aimeos content cache, use
php artisan aimeos:clear
During development, it's best to disable caching:
https://github.com/aimeos/aimeos-laravel#hints
Also, never overwrite the original templates as your changes will be lost as soon as a new version is installed. Instead, create your own extension and copy the templates you want to overwrite there:
There's an extension generator available:
https://aimeos.org/extensions
