manually added customers
Hello!
I have manually added customers (subscription -> Bank transfer).
I'm not sure if this is ok! Can anybody help me to resolve it?
Best & Thank's,
Goran
Best & Thank's,
Goran
- Clipboard 1.jpg (51.83 KiB) Viewed 7713 times
- bnaeadjjoeffbiec.png (43.06 KiB) Viewed 7716 times
Re: manually added customers
You have to set the "Next date" to the date when the next renewal should occur.
I have tried to add this date, but when I save, field is empty?
what will, with next interval 4weeks, automatically ??
Did you use the date selector offered? Which Aimeos version do you use?
just hidden attribute (interval) for each product/subscription!
20.10.8
20.10.8
I've meant the "Next date" field in the subscription detail panel because you've said you can't save a value for that field.
