order status import
akropivko
order status import
Post by akropivko » 16 Jun 2021, 07:31
Hi!
I need to implement order status changing based on .csv or .xml data from third-party system.
I guess it's about to import csv files using updateAsync() function from Payment/Delivery provider.
Could you please give me some step-by-step instruction what I should do to achieve this? What I've already understood from documentation I need to create a new Payment/Delivery provider with updateAsync() and then to create a new cron job to run this method periodically. Is it correct?
Or maybe this functionality already implemented but not documented yet?
Thanks!
Laravel 6.20.27
aimeos/aimeos-core 2020.10.24
PHP 7.4
Re: order status import
Post by aimeos » 18 Jun 2021, 05:33
Yes, you can use the already existing XML delivery service provider which implements the updateAsync method to update order status values: https://github.com/aimeos/aimeos-core/b ... #L134-L173
If that doesn't match your needs, you should implement a delivery service provider or decorator (if you already use a provider) yourself: https://aimeos.org/docs/latest/provider ... /delivery/
akropivko
Post by akropivko » 18 Jun 2021, 09:08
aimeos wrote: 18 Jun 2021, 05:33 Yes, you can use the already existing XML delivery service provider which implements the updateAsync method to update order status values: https://github.com/aimeos/aimeos-core/b ... #L134-L173
Is there any example of .xml file for order import to use with default configuration?
Post by aimeos » 22 Jun 2021, 07:30
Unfortunately not. The whole XML file handling is only barely documented yet and we appreciate any help!
