The path to new controllers, where should he be?
In shop.php, I added "mynameeerrr" to
and got an error
Tell me which path should I create this file "mynameeerrr"?
'client' => [
'html' => [
'checkout' => [
'confirm' => [
'name' => 'mynameeerrr',
Class "\ Aimeos \ Client \ Html \ Checkout \ Confirm \ mynameeerrr" not available
- Image20210714161813.png (15.36 KiB) Viewed 5399 times
- Image20210714161808.png (180.6 KiB) Viewed 5399 times
Re: The path to new controllers, where should he be?
Where did you store your new class?
Problem solved
- Bez tytułu2.png (76.48 KiB) Viewed 5391 times
- Bez tytułu.png (64.1 KiB) Viewed 5391 times
