[Solved in 21.4] - zeynepjs mobile-first navigation menu
I still wonder if the zeynepjs menu works as intended, or did I mess up somewhere?
I expected it to work like the menu used in nopCommerce.
Do I really have to click a main category first, and open the menu again in order to see the sub categories?
Re: zeynepjs mobile-first navigation menu
Use these configuration options fetch up to four levels of categories upfront in 2021.x:
https://github.com/aimeos/ai-client-htm ... hp#L15-L16
If you use 2020.10, you also have to set this option:
https://aimeos.org/docs/2020.x/config/c ... lter/#deep
I already followed your suggestions starting with version 21.4.2.
What I see is that the navigation is far from smooth.
Sometimes one just makes a little mistake and misses something.
Is there a live site where I can see it working?
I noticed that the main problem is in having a space in the category name.
F.e.:
Label = Main categories, breaks the navigation on mobile.
Renaming: Label = Maincategories, and it works like a charm.
This behaviour is also mentioned here:
https://github.com/hsynlms/zeynepjs/issues/11
F.e.:
- Screenshot from 2021-07-13 16-00-21.png (9.75 KiB) Viewed 10839 times
Can you please add a screenshot to the Github issue to solve this problem faster?
Use category IDs instead of names for node IDs
Does your change fix the problem, i.e. can I try it safely in a live environment? :
https://github.com/aimeos/ai-client-htm ... 7bdc050b17
This should circumvent the problem.
It certainly does, just tried it.
Thank you!!! )
Thank you!!! )
