21.7.1 Problems
21.7.1 Problems
Typo3 10.4.17 and AImeos: 21.7.1 after update from current aimeos version.
I have if i want to save in orders an order with changes following:
But in the account from user in frontend are germany setted, in customers in aimeos backend too. not in users from typo3.
ANd following error if i want to save :
its btw no country choosable where i want to save...
Im right that static_info_tables not needed anymore in the curretn version?
same at delivery and billing adress:
- saveerrorisocode2.png (2.35 KiB) Viewed 8313 times
Re: 21.7.1 Problems
Yes, the static_info_tables extension isn't used any more and the country IDs in the fe_users.static_info_country changed from three letters to two letters to comply to what other extensions are using. There's a setup task that converts the values.
Where in the admin backend is the country for the user address missing? In the customer panel?
Did you run the update script in the extension manager first?
Re: 21.7.1 Problems
first. thanks for the fast answer
i delete abou data base anylize the tables from the static_info_tables extension.
i did the update script.
where is these setup taskYes, the static_info_tables extension isn't used any more and the country IDs in the fe_users.static_info_country changed from three letters to two letters to comply to what other extensions are using. There's a setup task that converts the values.
only in the choosement from the first two pics in billing and deliveryadress. but only in the orders panle. not in the customers. there are the delivery and billing adress germany used, normalWhere in the admin backend is the country for the user address missing? In the customer panel?
Re: 21.7.1 Problems
The country ID in the order panel has already been fixed but the fix isn't part of 2.7.1 from TER. It will be part of the next minor release.
Re: 21.7.1 Problems
i think the next minor release in in around 30 days, isnt it?The country ID in the order panel has already been fixed but the fix isn't part of 2.7.1 from TER. It will be part of the next minor release.
Its possible because i wait so man month to can use aimeos without bugs, and every month something fixed and a new there,
to public "without guaranty" the fix for public or to send me per mail or direct message? Its maybe only a few lines code or 1 or two files to change, without to have new bugs have fixed that what i did see now. And without that fix its not possible to use aimeos in that version. and the last version didnt was possible to use selectionproducts, you remember . its better to work with newest version ingeneral i think because its changed so much things.
But i can tell here things i foung till now, seems they arent fixed at least, but they arent not importand to use aimeos:
- List view no stock level for selection products
- detail view no picture change for selection products
things you guys fixed to the vurrent version they work now in my installation:
- selectionproducts, with description and price and cart clicking
- stars ind detail view are stars again
Re: 21.7.1 Problems
If you use a composer based Aimeos installation, you can get the fixes immedately because we release Aimeos core packages quite often (once a week or within several days depending on the bugs that has been fixed). The ZIP package in TER is updated only every 3-4 weeks.
The fix for the countries in the order panel is this one:
https://github.com/aimeos/ai-admin-jqad ... 375f3d1069
In stable releases (x.4.y and x.7.y) we make changes which may introduce new bugs. The x.10.y LTS version receive bug fixes only and are rock solid.
Re: 21.7.1 Problems
nice i fixed it with your codeIf you use a composer based Aimeos installation, you can get the fixes immedately because we release Aimeos core packages quite often (once a week or within several days depending on the bugs that has been fixed). The ZIP package in TER is updated only every 3-4 weeks.
good to know
I found more things they dont work at least
1)selection products:
- Stocklevelview in listview
- EAN Number detailpage not changing if choose change
- Picture not changing if choose change
2) Pictures from SUGGESTED PRODUCTS are not visible if hovering with mouse about. looks like the photoswitcheffect from bundleproducts, but after the first is away no second areshowed for sure.
3) The basket if clicking "add to basket" (see picture) - if i delete from these two things:
- it redirect me to the basketpage. wich not happen with small basket.
- the small basket dont change the number of items in it.
Questions:
1) I think you changed the codesystem for vouchers, or im not smart anough only. Do you have adoku for that with complaining the different types:
Fixed RAbat, percentrabat, freeshipping, tip, present, voucher. im not smart anough anymore to create on code or these use autocreated features, that work in frontend.
FOr example an error, that filling the code in the basket after reload but before:
No payed Voucher avaible for code: VOuchername
Last problems:
For onepagercheckout. is witched because this many problems to normal steppager, but that you can fix it:
- It dont change live in summary and detailpart something if user change or already hooked the delivery, paymant, useradress oder deliveryadress. only "wie Rechnungsadresse" is prefilled.
Re: 21.7.1 Problems
Tested and works. It seems like you use an old JS file.Shopmister wrote: ↑27 Jul 2021, 07:54 - Stocklevelview in listview
This has never been implemented. You can create a feature request here:
https://github.com/aimeos/ai-client-html/issues
Tested and worksShopmister wrote: ↑27 Jul 2021, 07:54 2) Pictures from SUGGESTED PRODUCTS are not visible if hovering with mouse about. looks like the photoswitcheffect from bundleproducts, but after the first is away no second areshowed for sure.
This is as implemented.Shopmister wrote: ↑27 Jul 2021, 07:54 3) The basket if clicking "add to basket" (see picture)
Tested and works in a new distribution setup. As the number of items is updated by JS, there seems to be an old version or another problem in your setup.
- https://aimeos.org/docs/latest/manual/coupons/Shopmister wrote: ↑27 Jul 2021, 07:54 1) I think you changed the codesystem for vouchers, or im not smart anough only. Do you have adoku for that with complaining the different types:
- https://www.youtube.com/watch?v=b3p3GT7UlBQ
The complete summary shouldn't be part of the one page checkout. You can strip down the summary to the basket only but even then, the delivery costs aren't added to the basket details if they are selected in the delivery part.Shopmister wrote: ↑27 Jul 2021, 07:54 For onepagercheckout. is witched because this many problems to normal steppager, but that you can fix it:
