[Solved - Again v21.7] - [Solved in 21.4] - zeynepjs mobile-first navigation menu
There are some hiccups in the zeynep menu on mobile again in version 21.7
In 21.4 they were solved. Problem is again in sub-menus.
Sub-menus keep opening and can only be closed by clicking the back-arrow.
Love the new 21.7 version, great design!
Besides that it gives me much more a "TYPO3 feeling". Kudos!!
Re: Again v21.7 - [Solved in 21.4] - zeynepjs mobile-first navigation menu
Yes, we can confirm that there's a problem with the menu and we will check that.
We are glad you like the new theme
How do you define that "TYPO3 feeling"?
Problem has been fixed in aimeos/ai-client-html:2021.07.9
Great, it works fine, thank you!
However something is wrong now in the CSS for: .aimeos .catalog-stage-image
The image is placed wrong and does not have a height set to auto.
(Again a bit difficult to say without an example, my reference is a fresh distribution install).
- Before CSS changes
- Before CSS change.jpg (87.78 KiB) Viewed 18394 times
- After CSS changes
- After CSS change.jpg (53.91 KiB) Viewed 18394 times
Set "Frame" option in the flexfrom of the plugin to "No frame".
The result: (logo erased in the jpg)
Is it possible to post an example of what we should see?
- Screenshot from 2021-07-27 14-21-30.jpg (46.78 KiB) Viewed 18387 times
This is exactly how it should be.
Hmmm, in that case: was the image meant to be hidden on mobile?
Now only a silly small stripe is left.
When can we expect a live example of 21.7, or some screenshots - what are you hiding for us
It is impossible to see if (what) one is possibly missing something.
Of course one has the freedom of ones own design, however so far I am getting the feeling I do not make any progress, besides useless filling the database.
Would you advise me to switch over to the 20.10 branch which you mentioned to be rock solid?
This is how the new theme should look like:
https://themes.demo.aimeos.org/
Thank you ever so much, great help!!
