[Solved - Again v21.7] - [Solved in 21.4] - zeynepjs mobile-first navigation menu
ivanp
Re: [Solved] Again v21.7 - [Solved in 21.4] - zeynepjs mobile-first navigation menu
Post by ivanp » 28 Jul 2021, 10:12
One more last thing concerning the menu:
On large screens the parent category in the mega menu cannot be opened: href="#"
in the menu on mobile however it is an actual link.
Should the links on different screen sizes not behave in the same way?
An actual link could give the opportunity to place some additional content, or perhaps "less is more".
ivanp
Post by ivanp » 02 Aug 2021, 17:48
Re: "less is more"
However in the above case adding a standard type image under media, will show right from the link to the child, in the mega-menu.
The parent changes to a real clickable link.
Post by aimeos » 03 Aug 2021, 16:32
That has been streamlined now and the top level categories are clickable now. The submenus will be shown on hover.
Changes will be part of the next minor release.
Oscar
Re: [Solved - Again v21.7] - [Solved in 21.4] - zeynepjs mobile-first navigation menu
Post by Oscar » 20 Sep 2021, 07:10
I have an extension and I would like to know if it is possible to fix the closing submenus without arrows. The problem is in the js or css? is to be able to compare it with the new version. Thanks
ivanp
Post by ivanp » 20 Nov 2021, 10:12
Again, in version 21.10.2 the subcategories are not shown on hover.
Post by aimeos » 21 Nov 2021, 14:51
We can't reproduce the problem. In Aimeos TYPO3 distribution with Aimeos extension 21.7.2, subcategories are shown when hovering over the main categories if there are any subcategories:
ivanp
Post by ivanp » 21 Nov 2021, 15:48
As I wrote: Again, in version 21.10.2 ....
Post by aimeos » 22 Nov 2021, 09:16
ivanp wrote: 21 Nov 2021, 15:48 As I wrote: Again, in version 21.10.2 ....
Sorry, we did our test with 21.10.2 but have written the wrong version in the reply.
ivanp
Post by ivanp » 22 Nov 2021, 11:12
The subcategory is only shown on hovering after clicking/opening the main category.
The same behaviour on mobile: first click the main category -> main category opens, only now the subcategory is visible.
