Multiple Shops
Multiple Shops
In the Aimeos Documentations are described how to setup more than one Shop.
Do i need a further Extension to manage a second shop like described here?
http://aimeos.org/docs/User_Manual/Admi ... with_sites
http://aimeos.org/docs/TYPO3/Configure_multiple_shops
Thank you!
Or what should i do? because something is going wrong if i try like described.Furthermore, the we also offer an extension which enables you to add sub-shops that inherit products, categories, pictures, texts, etc. from a parent instance and you can even add more sites to these sub-shops without any restrictions in depth. This is perfect for market places or resellers.
Thank you!
- screen-multi3.jpg (42.55 KiB) Viewed 5105 times
- All plugin-settings in the sites of the "booking-tree" are changed.
- screen-multi2.jpg (225.14 KiB) Viewed 5105 times
- screen-multi1.jpg (213.77 KiB) Viewed 5105 times
Re: Multiple Shops
No that's not necessary if your shops are independent.alpin3rocker wrote: In the Aimeos Documentations are described how to setup more than one Shop.
The setup of an additional shop is a little bit tricky. Could you please try the following:alpin3rocker wrote: Or what should i do? because something is going wrong if i try like described.
* Rename your "default" site code to something else
* Go to the extension manager and click on the update button of the Aimeos web shop extension so it creates a new "default" site with all required database entries
* Now you can rename your new site code and the "default" site code again to their final names
* Your TS setup is OK as far as I can see but you also need to set the site code in the PageTS config as well (http://aimeos.org/docs/TYPO3/Configure_multiple_shops)
If it works for you too I will update the documentation.
Re: Multiple Shops
from the Log:
What else can i trie?
Thank you
i renamed it in "pending"* Rename your "default" site code to something else
i did this and get a third new "default" shop/site at the locale section in the Manager* Go to the extension manager and click on the update button of the Aimeos web shop extension so it creates a new "default" site with all required database entries
i renamed the new third shop from "default" to "test" and the "pending" back to "default"* Now you can rename your new site code and the "default" site code again to their final names
Yes that was made.* Your TS setup is OK as far as I can see but you also need to set the site code in the PageTS config as well (http://aimeos.org/docs/TYPO3/Configure_multiple_shops)
It doesn't work. Something is still going wrong.If it works for you too I will update the documentation.
from the Log:
Core: Error handler (FE): PHP Catchable Fatal Error: Argument 7 passed to Controller_Frontend_Basket_Default::addProduct() must be of the type array, string given, called in /schgbjxd/www.domain.at/typo62/typo3conf/ext/aimeos/Resources/Libraries/arcavias/arcavias-core/controller/frontend/src/Controller/Frontend/Basket/Default.php on line 649 and defined in /schgbjxd/www.domain.at/typo62/typo3conf/ext/aimeos/Resources/Libraries/arcavias/arcavias-core/controller/frontend/src/Controller/Frontend/Basket/Default.php line 85
Thank you
Re: Multiple Shops
That's not related to setting up multiple shops. Instead, it seems I've missed a line when trying to migrate ordered products between sites. Can you please update the core and try again?alpin3rocker wrote: It doesn't work. Something is still going wrong. from the Log:Code: Select all
Re: Multiple Shops
I've talked to the others and we were able to add the possibility to create and update arbitrary sites from within the Extension Manager. You need the latest TYPO3 and Core code to get this working.
In the Extension Manager, click on the Aimeos web shop extension and enter in the input field for the "Site code" your new string value (e.g. booking). Save the configuration and click on the "Update" button of the Aimeos web shop extension. This will create a new or update an existing site with the name you've entered into the input field.
That should ease things a lot in the future
