PHP API Docs
PHP API Docs
Hi Aimeos Team,
what happend to the https://aimeos.org/api/ - Docs? I liked to use it as a quick reference...
Best regards,
Nils
Best regards,
Nils
Re: PHP API Docs
It has been removed because the package for generating the documentation isn't supported any more. Symfony also removed the API documentation and their documentation generator is marked as archived (no further developement). There seem to be only phpdoc left for generating PHP API docs.
Re: PHP API Docs
Thanks for the quick answer. Are there any plans to re-publish the docs with phpdoc?
Re: PHP API Docs
You are the first one asking for it and nobody else seem to miss it ...
Re: PHP API Docs
Well, must be because I'm a lazy developer using Notepad++ as my "SDE" and Google as my API reference most of the time Okay, nevermind, I'm going to find a way.
