Problem with sending scheduled e-mails
boettner
Re: Problem with sending scheduled e-mails
Post by boettner » 15 Jun 2015, 14:20
This is my locale tab
Post by aimeos » 15 Jun 2015, 21:36
Which TYPO3 and Aimeos versions are you using?
boettner
Post by boettner » 16 Jun 2015, 05:41
aimeos wrote:Which TYPO3 and Aimeos versions are you using?
TYPO3 6.2.12 and Aimeos 2.2.2
WahnM
Post by WahnM » 16 Jun 2015, 08:24
Same versions (6.2.12 and 2.2.2 from TER)
Post by aimeos » 16 Jun 2015, 12:46
The problem was a NULL value for the country ID that caused the the Zend translator implementation to generate a warning. Could you please install this version and try again: http://aimeos.org/fileadmin/download/aimeos_2.2.3.zip
It should fix the problem and will be the base for the next minor release.
Many thanks to Robert for this help!
boettner
Post by boettner » 16 Jun 2015, 16:18
Thanks for this fix and your support, looks great.
Still have a problem with the cronjob itself though. But thats related to ISPConfig and OS user rights I think. Will track that down tomorrow.
WahnM
Post by WahnM » 19 Jun 2015, 09:40
zend problem is fixed now. But the scheduler does not send mails automatically. I think it has nothing to do with the aimeos-task.
If I find a solution I will post it here.
Best wiches and thx for the support.
Marcus
Post by aimeos » 19 Jun 2015, 10:05
In Roberts installation we've seen a misconfiguration by executing the e-mail jobs in the standard Aimeos scheduler task too. This causes log entries in the madmin_log table due to missing settings. Maybe there are also some hints in your log table.
WahnM
Post by WahnM » 19 Jun 2015, 12:46
I have found "Item with ID "" in "product.id" not found" in the madmin_log, but the producty have IDs?!
Any ideas?
M
WahnM
Post by WahnM » 19 Jun 2015, 12:48
Here is the task. Anything wrong?
