Problem with sending scheduled e-mails
Re: Problem with sending scheduled e-mails
Post by aimeos » 19 Jun 2015, 13:31
WahnM wrote: I have found "Item with ID "" in "product.id" not found" in the madmin_log, but the producty have IDs?!
Those log entries are from the front-end because they have a request ID, so your scheduler tasks seem to be correctly configured. Are e-mails sent at all, e.g. if you execute the task manually?
Post by aimeos » 19 Jun 2015, 13:33
WahnM wrote:Here is the task. Anything wrong?]
No, your task seem to be totally fine.
The main failure you can do is to execute the e-mail related tasks in the general Aimeos scheduler too.
WahnM
Post by WahnM » 19 Jun 2015, 15:42
Everything is fine now. I've configured a cronjob for the scheduler on the server via ssh. The task is now scheduled.
Thank for your very (!) quick response. Until next time :-)
Marcus
