Details Page Error
Details Page Error
Yesterday I installed a new Instance of Symfony aimeos bundle. Everything works flawlessly, except the details page . Where aimeos shows an error on details page: A non-recoverable error occured
The error appears in this template block:
{% block aimeos_body %}
{{ aibody['catalog/detail']|raw }}
{% endblock %}
From madmin_log table:
Executing statement "
SELECT DISTINCT mmedli."id", mmedli."parentid", mmedli."siteid",
mmedli."typeid", mmedli."domain", mmedli."refid",
mmedli."start", mmedli."end", mmedli."config", mmedli."pos",
mmedli."status", mmedli."mtime", mmedli."editor",
mmedli."ctime"
FROM "mshop_media_list" AS mmedli
WHERE ( mmedli."siteid" IN (1) AND ( mmedli."parentid" IN (12,13,14,15) AND mmedli."domain" IN ('media','price','text','attribute','product') AND ( mmedli."status" = 1 AND ( mmedli."start" <= '2015-09-01 11:29:00' OR mmedli."start" IS NULL ) AND ( mmedli."end" >= '2015-09-01 11:29:00' OR mmedli."end" IS NULL ) ) ) )
LIMIT 2147483647 OFFSET 0
" failed: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'testaimeos.mshop_media_list' doesn't exist
#0 C:\xampp\htdocs\testaimeos\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Common\Manager\Abstract.php(837): MW_DB_Statement_PDO_Simple->execute()
#1 C:\xampp\htdocs\testaimeos\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Common\Manager\List\Abstract.php(360): MShop_Common_Manager_Abstract->_searchItems(Object(MW_DB_Connection_PDO), Object(MW_Common_Criteria_SQL), 'mshop/media/man...', 'mshop/media/man...', Array, NULL, 3)
#2 C:\xampp\htdocs\testaimeos\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Common\Manager\Decorator\Abstract.php(168): MShop_Common_Manager_List_Abstract->searchItems(Object(MW_Common_Criteria_SQL), Array, NULL)
#3 C:\xampp\htdocs\testaimeos\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Common\Manager\ListRef\Abstract.php(102): MShop_Common_Manager_Decorator_Abstract->searchItems(Object(MW_Common_Criteria_SQL))
#4 C:\xampp\htdocs\testaimeos\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Common\Manager\ListRef\Abstract.php(46): MShop_Common_Manager_ListRef_Abstract->_getListItems(Array, Array, 'media')
#5 C:\xampp\htdocs\testaimeos\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Media\Manager\Default.php(553): MShop_Common_Manager_ListRef_Abstract->_buildItems(Array, Array, 'media')
#6 C:\xampp\htdocs\testaimeos\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Common\Manager\Decorator\Abstract.php(168): MShop_Media_Manager_Default->searchItems(Object(MW_Common_Criteria_SQL), Array, NULL)
#7 C:\xampp\htdocs\testaimeos\vendor\aimeos\aimeos-core\client\html\src\Client\Html\Catalog\Detail\Default.php(517): MShop_Common_Manager_Decorator_Abstract->searchItems(Object(MW_Common_Criteria_SQL), Array)
#8 C:\xampp\htdocs\testaimeos\vendor\aimeos\aimeos-core\client\html\src\Client\Html\Catalog\Detail\Default.php(289): Client_Html_Catalog_Detail_Default->_setViewParams(Object(MW_View_Default), Array, NULL)
#9 C:\xampp\htdocs\testaimeos\vendor\aimeos\aimeos-symfony2\Service\Page.php(62): Client_Html_Catalog_Detail_Default->getHeader()
#10 C:\xampp\htdocs\testaimeos\vendor\aimeos\aimeos-symfony2\Controller\CatalogController.php(43): Aimeos\ShopBundle\Service\Page->getSections('catalog-detail')
#11 [internal function]: Aimeos\ShopBundle\Controller\CatalogController->detailAction()
#12 C:\xampp\htdocs\testaimeos\app\bootstrap.php.cache(3109): call_user_func_array(Array, Array)
#13 C:\xampp\htdocs\testaimeos\app\bootstrap.php.cache(3071): Symfony\Component\HttpKernel\HttpKernel->handleRaw(Object(Symfony\Component\HttpFoundation\Request), 1)
#14 C:\xampp\htdocs\testaimeos\app\bootstrap.php.cache(3222): Symfony\Component\HttpKernel\HttpKernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#15 C:\xampp\htdocs\testaimeos\app\bootstrap.php.cache(2444): Symfony\Component\HttpKernel\DependencyInjection\ContainerAwareHttpKernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#16 C:\xampp\htdocs\testaimeos\web\app_dev.php(28): Symfony\Component\HttpKernel\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request))
#17 {main}
I couldn't solve the error. Please help .
Thank You
{% endblock %}
mmedli."ctime"
#17 {main}
Thank You
- aimeos_details_error.jpg (85.19 KiB) Viewed 345454 times
Re: Details Page Error
You somehow deleted the mshop_media_list table from your database. To recreate it, run:siddharthamahata wrote: From madmin_log table:
php app/console aimeos:setup
resource:
db:
opt-persistent: 1
Sir.
This error is a bit wierd. I ran the setup and it worked fine.
But the table mshop_media_list did not get created.
It was not deleted, but somehow not being created during the setup procedure.
The setup lines say OK on checking mshop_media_list in the console window.
I am sorry for the trouble.
Can you tell me the structure of mshop_media_list , so i can create it manually.
Or if you can send me the sql command to create it.
It would be of great help.
The other option is as it should be, "opt-persistent: 0".
Thank You
Thank You
If it's not there, it should output "created" instead.siddharthamahata wrote: This error is a bit wierd. I ran the setup and it worked fine.
Can you please run aimeos:setup on an empty database if it happens there too?
You shouldn't create the table by hand as this may only lead to problems later when changes should be applied to the table. If you can help to find the root cause, we can fix the underlying problem. How many mshop_* tables do you have in your database and in the new one? Is there a difference?siddharthamahata wrote: Can you tell me the structure of mshop_media_list , so i can create it manually.
Thank you very much
I created a new database and ran the aimeos setup there, but it still misses the creation of mshop_media_list.
It creates 62 tables in total.
I cannot compare my old database with this new one , as i dont have it right now.
It will take a few hours for me to go home and check.
I guess i am missing something. I will surely check my old db and report asap.
Thank you.
Thank you.
Hm, that's not enough. It should be 71 in total, 4 starting with "fos_user", 4 with "madmin_" and 63 with "mshop_" or is your total for the "mshop_" tables only?siddharthamahata wrote:I created a new database and ran the aimeos setup there, but it still misses the creation of mshop_media_list.
Here are the tables that should be created. Can you please post your table list too?
mysql> show tables;
| Tables_in_symfony |
| fos_user |
| fos_user_address |
| fos_user_list |
| fos_user_list_type |
| madmin_cache |
| madmin_cache_tag |
| madmin_job |
| madmin_log |
| mshop_attribute |
| mshop_attribute_list |
| mshop_attribute_list_type |
| mshop_attribute_type |
| mshop_catalog |
| mshop_catalog_index_attribute |
| mshop_catalog_index_catalog |
| mshop_catalog_index_price |
| mshop_catalog_index_text |
| mshop_catalog_list |
| mshop_catalog_list_type |
| mshop_coupon |
| mshop_coupon_code |
| mshop_customer |
| mshop_customer_address |
| mshop_customer_group |
| mshop_customer_list |
| mshop_customer_list_type |
| mshop_locale |
| mshop_locale_currency |
| mshop_locale_language |
| mshop_locale_site |
| mshop_media |
| mshop_media_list |
| mshop_media_list_type |
| mshop_media_type |
| mshop_order |
| mshop_order_base |
| mshop_order_base_address |
| mshop_order_base_coupon |
| mshop_order_base_product |
| mshop_order_base_product_attr |
| mshop_order_base_service |
| mshop_order_base_service_attr |
| mshop_order_status |
| mshop_plugin |
| mshop_plugin_type |
| mshop_price |
| mshop_price_list |
| mshop_price_list_type |
| mshop_price_type |
| mshop_product |
| mshop_product_list |
| mshop_product_list_type |
| mshop_product_property |
| mshop_product_property_type |
| mshop_product_stock |
| mshop_product_stock_warehouse |
| mshop_product_tag |
| mshop_product_tag_type |
| mshop_product_type |
| mshop_service |
| mshop_service_list |
| mshop_service_list_type |
| mshop_service_type |
| mshop_supplier |
| mshop_supplier_address |
| mshop_supplier_list |
| mshop_supplier_list_type |
| mshop_text |
| mshop_text_list |
| mshop_text_list_type |
| mshop_text_type |
71 rows in set (0.02 sec)
set session sql_mode='ansi';
CREATE TABLE "mshop_media_list" (
-- Unique list id
"id" INTEGER NOT NULL AUTO_INCREMENT,
-- media id (parent id)
"parentid" INTEGER NOT NULL,
-- site id, references mshop_locale_site.id
"siteid" INTEGER NOT NULL,
-- typeid
"typeid" INTEGER NOT NULL,
-- domain (e.g.: text, attribute)
"domain" VARCHAR(32) NOT NULL,
-- Reference of the object in given domain
"refid" VARCHAR(32) NOT NULL,
-- Valid from
"start" DATETIME DEFAULT NULL,
-- Valid until
"end" DATETIME DEFAULT NULL,
-- Configuration
"config" TEXT NOT NULL,
-- Precedence of the promotion
"pos" INTEGER NOT NULL,
-- status code (0=hidden, 1=display, >1 for anything special)
"status" SMALLINT NOT NULL DEFAULT 0,
-- Date of last modification of this database entry
"mtime" DATETIME NOT NULL,
-- Date of creation of this database entry
"ctime" DATETIME NOT NULL,
-- Editor who modified this entry at last
"editor" VARCHAR(255) NOT NULL,
CONSTRAINT "pk_msmedli_id"
PRIMARY KEY ("id"),
CONSTRAINT "unq_msmedli_sid_dm_rid_tid_pid"
UNIQUE ("siteid", "domain", "refid", "typeid", "parentid"),
CONSTRAINT "fk_msmedli_pid"
FOREIGN KEY ("parentid")
REFERENCES "mshop_media" ("id")
ON UPDATE CASCADE
ON DELETE CASCADE,
CONSTRAINT "fk_msmedli_typeid"
FOREIGN KEY ( "typeid" )
REFERENCES "mshop_media_list_type" ("id")
ON DELETE CASCADE
ON UPDATE CASCADE
) ENGINE=InnoDB DEFAULT CHARSET=utf8;
I executed the sql syntax given in the db. but it returns an error.
ERROR:
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '"mshop_media_list" (
-- Unique list id
"id" INTEGER NOT NULL AUTO_INCREM' at line 1
I guess the mysql dosent match with the version required .
in Php myadmin it shows:
Server version: 5.6.21 - MySQL Community Server (GPL)
Apache/2.4.10 (Win32) OpenSSL/1.0.1i PHP/5.6.3
Database client version: libmysql - mysqlnd 5.0.11-dev - 20120503
The count 62 tables is the complete list of tables.
fos_user
fos_user_address
fos_user_list
fos_user_list_type
madmin_cache
madmin_cache_tag
madmin_job
madmin_log
mshop_attribute
mshop_catalog
mshop_catalog_list
mshop_coupon
mshop_coupon_code
mshop_customer
mshop_locale
mshop_locale_site
mshop_media
mshop_media_type
mshop_order
mshop_order_base
mshop_order_status
mshop_plugin
mshop_plugin_type
mshop_price
mshop_price_type
mshop_product
mshop_product_list
mshop_product_stock
mshop_product_tag
mshop_product_type
mshop_service
mshop_service_list
mshop_service_type
mshop_supplier
mshop_supplier_list
mshop_text
mshop_text_type
ERROR:
-- Unique list id
fos_user
fos_user_address
fos_user_list
fos_user_list_type
madmin_cache
madmin_cache_tag
madmin_job
madmin_log
mshop_attribute
mshop_catalog
mshop_catalog_list
mshop_coupon
mshop_coupon_code
mshop_customer
mshop_locale
mshop_locale_site
mshop_media
mshop_media_type
mshop_order
mshop_order_base
mshop_order_status
mshop_plugin
mshop_plugin_type
mshop_price
mshop_price_type
mshop_product
mshop_product_list
mshop_product_stock
mshop_product_tag
mshop_product_type
mshop_service
mshop_service_list
mshop_service_type
mshop_supplier
mshop_supplier_list
mshop_text
mshop_text_type
When using phpmyadmin, you have to execute the "set session ..." statement along with the "create table ..." statement:siddharthamahata wrote: #1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '"mshop_media_list" (
-- Unique list id
SET SESSION SQL_MODE='ANSI';
CREATE TABLE "mshop_media_list_type" (
-- Unique id
-- domain
-- code
"code" VARCHAR(32) NOT NULL COLLATE utf8_bin,
-- Name of the list type
"label" VARCHAR(255) NOT NULL,
-- Status (0=disabled, 1=enabled, >1 for special)
"status" SMALLINT NOT NULL,
CONSTRAINT "pk_msmedlity_id"
PRIMARY KEY ("id"),
CONSTRAINT "unq_msmedlity_sid_dom_code"
UNIQUE ("siteid", "domain", "code")
-- Unique list id
-- typeid
-- Valid from
-- Valid until
-- Configuration
PRIMARY KEY ("id"),
ON UPDATE CASCADE
ON DELETE CASCADE,
ON DELETE CASCADE
ON UPDATE CASCADE
In your database, half of the list type and list tables are missing:siddharthamahata wrote: The count 62 tables is the complete list of tables.
- attribute list/list type : OK
- catalog list/list type : OK
- customer list/list type : missing
- media list/list type : missing
- price list/list type : missing
- product list/list type : OK
- service list/list type : OK
- text list/list type : missing
Which version of the Aimeos Symfony bundle are you using? 1.1.x?
symfony version - 2.7.3
"aimeos/aimeos-symfony2": "dev-master"
how to check the exact version of aimeos?
I ran the sql statement as you said. i.e along with set session , and it worked .
It succesfully created two tables ,
1. mshop_media_list
2. mshop_media_list_type
1. mshop_media_list
The only way I know for dev-master is to look into the composer.lock file.siddharthamahata wrote: how to check the exact version of aimeos?
Very strange ...siddharthamahata wrote: I ran the sql statement as you said. i.e along with set session , and it worked .
1. mshop_media_list
Can you please execute this statement and tell me what is the result? Please replace "<dbname>" by the name of the database you've installed Aimeos in.
SELECT TABLE_NAME
FROM INFORMATION_SCHEMA.TABLES
WHERE TABLE_TYPE = 'BASE TABLE'
AND TABLE_SCHEMA = '<dbname>'
AND TABLE_NAME = 'mshop_price_list'
