basket in bootstrap_package navigation
I'm using TYPO3 7.4.
I'm struggling with the mini basket to insert it into the bootstrap_package navigation.
I've read "https://aimeos.org/docs/TYPO3/Add_basket_to_navigation" and tried it in a very simple way. I put
lib.navigation.basket = COA
lib.navigation.basket.10 = USER
lib.navigation.basket.10 {
userFunc = tx_extbase_core_bootstrap->run
# userFunc = TYPO3\CMS\Extbase\Core\Bootstrap->run
# vendorName = Aimeos
extensionName = Aimeos
pluginName = basket-small
controller = Basket
action = small
settings =< plugin.tx_aimeos.settings
into to the root setup of my website and added
plugin.tx_aimeos.settings.client.html.basket.standard.url.target = <16>
the page ID of my basket page. Then added
<f:if condition="{f:cObject(typoscriptObjectPath:'lib.navigation.basket')}">
<f:cObject typoscriptObjectPath="lib.navigation.basket" />
</f:if>
into the Private/Partials/Page/Navigation/Main.html template. But there's no basket in the navigation. Adding other TS Objects instead of lib.navigation.basket works fine.
Thanks for any help.
Trimble
controller = Basket
action = small
</f:if>
Trimble
Re: basket in bootstrap_package navigation
Please use the two lines above instead.trimble wrote: I'm using TYPO3 7.4.
lib.navigation.basket.10 { userFunc = TYPO3\CMS\Extbase\Core\Bootstrap->run vendorName = Aimeos
Thanks for the quick answer. Now I see 2 (!) baskets.aimeos wrote:Please use the two lines above instead.trimble wrote: I'm using TYPO3 7.4.
<div class="body-bg body-bg-top">
<a class="sr-only sr-only-focusable" href="#content">
Skip to main content
</a>
<header
class="navbar navbar-default navbar-has-image navbar-top navbar-fixed-top">
<div class="container">
<section class="aimeos basket-mini">
<h1>Warenkorb</h1>
<a href="">
<div class="basket-mini-main">
<span class="quantity">0 Artikel</span>
<span class="value">0.00 €</span>
</div>
</a>
</section>
<div class="navbar-header navbar-header-main">
<a class="navbar-brand navbar-brand-image" href="/home.html">
<img src="/fileadmin/_processed_/csm_logo_ce268eadd3.gif" alt="Logo: XXXXXXXXXXX" height="114" width="126">
</a>
<button class="navbar-toggle collapsed" type="button" data-toggle="collapse" data-target=".navbar-collapse">
<span class="sr-only">Toggle navigation</span>
<span class="icon-bar"></span>
</button>
<span class="navbar-header-border-bottom"></span>
<div class="basket"><section class="aimeos basket-mini">
<h1>Warenkorb</h1>
<a href="">
</div>
</a>
</section></div>
This is the main template:
class="navbar navbar-{themeNavigationstyle}{f:if(condition:logoFile,then:' navbar-has-image')}{f:if(condition:themeNavigationtype, else:' navbar-top', then:' navbar-{themeNavigationtype} navbar-fixed-{themeNavigationtype}')}">
</f:if>
<f:if condition="{logoFile}">
<f:then>
<f:link.page pageUid="{rootPage}" class="navbar-brand navbar-brand-image">
<img src="{f:uri.image(src: logoFile)}" alt="{logoAlt}" height="{logoHeight}" width="{logoWidth}">
</f:link.page>
</f:then>
<f:else>
<f:link.page pageUid="{rootPage}" class="navbar-brand">{siteTitle}</f:link.page>
</f:else>
</f:if>
<f:if condition="{f:cObject(typoscriptObjectPath:'lib.navigation.main')}">
</button>
</f:if>
<div class="basket"><f:cObject typoscriptObjectPath="lib.navigation.basket" /></div>
</f:if>
</div>
<nav class="navbar-collapse collapse" role="navigation">
<f:cObject typoscriptObjectPath="lib.navigation.main"/>
</nav>
</div>
</header>
And this is the lib.navigation.basket in the root setup
vendorName = Aimeos
controller = Basket
action = small
One more question: The standard basket isn't found. Is it correct to write uid with brackets?
Thanks for youe help
Trimble
Well, you've added it twice in your TypoScripttrimble wrote: Thanks for the quick answer. Now I see 2 (!) baskets.
<div class="container"> <f:if condition="{f:cObject(typoscriptObjectPath:'lib.navigation.basket')}"> <f:cObject typoscriptObjectPath="lib.navigation.basket" /> </f:if> ... <span class="navbar-header-border-bottom"></span> <f:if condition="{f:cObject(typoscriptObjectPath:'lib.navigation.basket')}"> <div class="basket"><f:cObject typoscriptObjectPath="lib.navigation.basket" /></div> </f:if> </div> <nav class="navbar-collapse collapse" role="navigation"> <f:cObject typoscriptObjectPath="lib.navigation.main"/> </nav> </div> </header>
No, the ID must be 16, not <16>.trimble wrote: One more question: The standard basket isn't found. Is it correct to write uid with brackets?Code: Select all
Oh my good, I checked it twice .
Thanks for your better eyes !
Trimble
Trimble
