catalog-filter-tree
trimble
catalog-filter-tree
Post by trimble » 14 Sep 2015, 19:10
how can i remove javascript from catalog-filter-tree? I want to style the tree without any animation.
Regards
Trimble
trimble
Re: catalog-filter-tree
Post by trimble » 15 Sep 2015, 20:25
sorry for my last post. I haven't worked with aimeos for the last months and forgot, that I asked the question in may and got a great answer:
help-f15/open-list-of-categories-t422.html
But now I run into a new problem.
I defined several categories (pix_1)
and added two catalog filters in list view. One filter starts with 'Holz' the other with 'Wolle' (pix_2)
. When I try to open for example 'Schurwolle' I get an error message (pix_3)
With only one catalog filter there are no problems.
Thanks for any help
Trimble
Post by aimeos » 15 Sep 2015, 23:11
trimble wrote: I defined several categories and added two catalog filters in list view. With only one catalog filter there are no problems.
Interesting combination. I think nobody tried adding the categories filter twice yet.
What you do want to achieve? Maybe there's a simpler solution.
trimble
Post by trimble » 16 Sep 2015, 09:16
I want to place different parts of the categories at different places on the same website.
Regards
Trimble
Post by aimeos » 16 Sep 2015, 11:03
trimble wrote: I want to place different parts of the categories at different places on the same website.
Hm, that doesn't work at the moment because there's the exception thrown you've mentioned.
We will see how we can change that.
trimble
Post by trimble » 16 Sep 2015, 11:10
The possibility of splitting the presentation of the categories would be great feature. Thanks for thinking about it.
nos3
Post by nos3 » 16 Sep 2015, 13:19
Hi Trimble
trimble wrote:The possibility of splitting the presentation of the categories would be great feature. Thanks for thinking about it.
I've saw your request and dared to make a small patch that should fix your problem :-)
https://github.com/aimeos/aimeos-core/pull/38
Norbert
Post by aimeos » 16 Sep 2015, 14:45
nos3 wrote: I've saw your request and dared to make a small patch that should fix your problem :-)
Cool! We've already merged your PR and it will be part of the release next month.
trimble
Post by trimble » 16 Sep 2015, 15:56
That sounds great. Thanks a lot!
I tried to integrate the patch into my TYPO3-Installation with aimeos 2.3.1. But I couldn't. The file
\typo3conf\ext\aimeos\Resources\Libraries\aimeos\aimeos-core\client\html\src\Client\Html\Catalog\Filter\Tree\default.php seeems to be different. Do I miss something?
Trimble
Post by aimeos » 16 Sep 2015, 16:10
trimble wrote:The file
Yes, the 2015.07 and master branch are different in that code block. But I think you can replace the if/elseif/else block completely with the if/if code block from the master branch.
