importer mapper and example csv
Hey,
I am using your exaple csv from - https://aimeos.org/docs/Developers/Cont ... s_from_CSV
I am also using the example mappings and this is how it looks in my config
However when I run
I get the following error -
any ideas ?
'common' => array(
'product' => array(
'import' => array(
'csv' => array(
'mapping' => array(
'item' => array(
1 => 'product.label', // UTF-8 encoded text, also used as product name
2 => 'product.type', // type of the product, e.g. "default" or "selection"
3 => 'product.status', // enabled (1) or disabled (0)
'text' => array(
6 => 'text.type', // e.g. "long" for long description
7 => 'text.content', // UTF-8 encoded text
'media' => array(
8 => 'media.url', // relative URL of the product image on the server
'price' => array(
9 => 'price.quantity', // the quantity the price is valid from (for block pricing)
10 => 'price.value', // price with decimals separated by a dot, no thousand separator
11 => 'price.taxrate', // tax rate with decimals separated by a dot
'attribute' => array(
12 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
13 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
'product' => array(
14 => 'product.code', // e.g. EAN code of another product
15 => 'product.list.type', // e.g. "suggestion" for suggested product
'property' => array(
16 => 'product.property.value', // arbitrary value for the corresponding type
17 => 'product.property.type', // e.g. "package-weight"
'catalog' => array(
18 => 'catalog.code', // e.g. Unique category code
19 => 'catalog.list.type', // e.g. "promotion" for top seller products
php artisan aimeos:jobs product/import/csv
Invalid product lines in 3/3
Re: importer mapper and example csv
The madmin_log table contains more information about the errors that have occurred. You can see all messages in the first tab of the admin interface.obayesshelton wrote: I am using your exaple csv from - https://aimeos.org/docs/Developers/Cont ... s_from_CSV
I get the following error -Code: Select all
In this case, the example file references a category (root) that doesn't exist. I've uploaded a new file that fixed the error. When importing you will now see 1 of 3 lines fails as long as you don't configure to skip the first line:
https://aimeos.org/docs/Configuration/C ... skip-lines
