Sorting the default catalog list
thomasu
Post by thomasu » 24 Nov 2015, 18:56
I'm searching for a way to sort the way products are displayed in the main catalog. (e.g. when you're visiting "/shop" or "/shop/list")
I'm able to sort products in their specific catalogs by dragging them around under Catalog -> Product.
The main catalog however seems to take every product that is attached to a catalog but sorts them by ID as far as i could tell.
Is it possible to change that sorting behaviour?
Greetings,
Thomas
nos3
Re: Sorting the default catalog list
Post by nos3 » 24 Nov 2015, 21:40
thomasu wrote:I'm searching for a way to sort the way products are displayed in the main catalog. (e.g. when you're visiting "/shop" or "/shop/list")
By default, the main product list is not bound to a category but it displays all products like you've described. This is caused because there is no category ID available.
To get the behavior you want, you can set a default category ID (e.g. the ID of the root category) using
https://aimeos.org/docs/Configuration/C ... id-default
Norbert
thomasu
Post by thomasu » 27 Nov 2015, 09:27
Thanks!
That did the trick.
