Overwrite existing templates (Laravel)
Re: Overwrite existing templates (Laravel)
Well there is nothing wrong with extension . Problem was extension was not getting autoloaded . so i added
to composer.json file . And it started working , But it gives Ambiguous class resolution Warning in on composer update . So let me know if you have any thoughts about it . Thanks
"psr-0": {
"Client_Html": "ext/extension-name/client/html/src"
Did you've copied the client/html/src/ directory too? If yes, you must not do this!
Remove the classes and if you want to overwrite one, create that class with a different name and extend from the original class. Then you can configure the name of your new class.
please see attachment
- this is how extension is inside extension folder . ext/mnamr and then files can be seen in screenshot . let me know how it should be ? thanks
- Screen Shot 2016-02-02 at 2.33.15 AM.png (27.81 KiB) Viewed 2913 times
As I can see no files, it's difficult to say if everything is correct.
You should check this again:
- Do you use Laravel 5.1 LTS (5.2 made some problems up to last week)
- Do you use the Aimeos Laravel 1.x package for Laravel 5.1
- Did you create the right extension version (2015.x) at https://aimeos.org/developer/extensions/
- Only copy the "catalog/detail/body-default.html" template to the same location in your extension ("client/html/layouts/catalog/detail/body-default.html") and make a test change in the HTML code
- Clear your cache with "./artisan aimeos:cache"
- Check if the test change is visible in the catalog detail view
Laravel 5.2 works with Aimeos Laravel 2016.01 since last week.
