How to keep categories tree expanded?
Questions around the TYPO3 integration and plugins as well as Flow and NeosCMS
abcdomino
Post by abcdomino » 17 Jan 2016, 10:25
Another issue that I'm struggling for is how to keep categories tree (in the catalog filter) expanded when the site is being loaded?
Best regards,
Dominik
Re: How to keep categories tree expanded?
Post by aimeos » 17 Jan 2016, 11:48
abcdomino wrote:Another issue that I'm struggling for is how to keep categories tree (in the catalog filter) expanded when the site is being loaded?
You need to overwrite the Javascript function for the catalog filter tree in the theme (aimeos.js). The setupCategoryToggle() is one of the method of the AimeosCatalogFilter object which you have to overwrite:
https://aimeos.org/docs/Developers/Them ... Javascript
abcdomino
Post by abcdomino » 18 Jan 2016, 14:56
Thanks a lot, I will be trying...
Best Regards,
Dominik
joakim
Post by joakim » 29 Jan 2016, 11:49
Use CSS to show the menu initially:
.catalog-filter-tree > ul {
	display: block;
Optionally hide the Categories header:
.catalog-filter-tree > h2 {
	display: none;
