How to set the tax flag
I want the shop to display all prices without VAT. According to the code, this is checked upon the $price->getTaxFlag() method.
Where can I set this value to be 0 for the complete shop?
Claudia
Claudia
Re: How to set the tax flag
Please use this configuration setting:cnoelker wrote:Where can I set this value to be 0 for the complete shop?
https://aimeos.org/docs/Configuration/C ... ce/taxflag
Thanks, got this working!
There's now a complete article regarding B2B setups available:
https://aimeos.org/docs/User_Manual/Setup_B2B_shop
I used
plugin.tx_aimeos.settings.mshop.price.taxflag = 0
too, but the taxes are shown in the basket and are also wrong calculated (see image in the attachment).
I used
- shop_taxes.png (39.13 KiB) Viewed 3778 times
Where did you set it? It must be in the setup TS-Config of your (shop) root page so it inherits to all pages below. Furthermore, you have to set it in the TS-Config field of the scheduler task as well so it's used in the e-mails.
I set the code into the root template of the page.
Where can I manipulate the tax...e.g. from 20% to 7% ?
Each price has a tax rate associated. The tax in your case comes from the delivery service option.
Ok.
But the system calculated the tax wrong (see image)
7% - > 15€ x 0,07 = 1,05€
19,00% -> 4,95€ x 0,19 = 0,94€
- shop_taxes_2.png (34.87 KiB) Viewed 3757 times
The tax flag configuration is still not used in your basket page because of "Inkl. ... MwSt". When it's used, "+ ...% MwSt" would be shown instead. Please check in the Typoscript object browser if the taxflag setting is available in your basket page resp. why it's not.
