PHP7 and overlay window for the basket
I'm using TYPO3 v7.6.4 and aimeos v16.1.2. With PHP 5.6 everything is fine. With PHP 7.0 the overlay window for the basket is opened but remains empty. Do I miss something?
Regards
trimble
Regards
trimble
Re: PHP7 and overlay window for the basket
At aimeos.com, it runs quite nicely with PHP 7: https://aimeos.com/support/
Can you have a look into the Apache error.log file and open the web console in your browser if there are any errors displayed?
Good morning,
I tried to check the situation with firebug and got the following error messages (error_messages1).
There is only one situation, when the windows opens correctly: The stock is empty.
Regards
trimble
Regards
trimble
- error_messages1.png (6.38 KiB) Viewed 5750 times
Could you please have a look into the response of the "count" and "stock" requests? Seems like HTML is returned which may be caused by an exception caught by TYPO3.
Here is the response of the count request. I deleted the empty lines
<div id="c14" class="frame default">
<h1 class="">
Counts
</h1>
var categoryCounts = {"1":"6","2":"3","3":"5","4":"2","5":"2","8":"1"};
$( ".catalog-filter-count li.cat-item" ).each( function( index, item ) {
var itemId = $(item).data( "id" );
$("> a.cat-item", item).append( function() {
if( categoryCounts[itemId] ) {
return ' <span class="cat-count">' + categoryCounts[itemId] + '</span>';
$(item).addClass( 'disabled' );
var attributeCounts = {};
$( ".catalog-filter-attribute .attribute-lists li.attr-item" ).each( function( index, item ) {
$(item).append( function() {
var itemId = $(this).data( "id" );
if( attributeCounts[itemId] ) {
var node = document.createElement( 'span' );
node.appendChild( document.createTextNode( attributeCounts[itemId] ) );
$(node).addClass( 'attr-count' );
return node;
$(this).addClass( 'disabled' );
</div>
You've added a header and a frame in the plugin settings. Thus, TYPO3 renders the div and h1 tag and that causes a JS error.
I didn't add anything. I'm testing the new bootstrap_package v7, I guess that's where it comes from (https://github.com/benjaminkott/bootstrap_package)
With ph 5.6 and bootstrap_package v7 I have the same error messages but that's no problem for the rendering of the overlay window.
Regards
trimble
15 min later:
I just ckecked it again with a reinstalled bootstrap_package 6.1.2. There aren't any errors
Regards
trimble
15 min later:
You should open a bug report for the bootstrap package
bootstrap_package v7 released today. I'm curious abourt your experiences with it.
Just one more information:
with the extension sourceopt I could clean the FE code. As result I get same errors but another output 'return window.wrappedJSObject || window;'
and I get the error message:
<b>Fatal error</b>: Declaration of Aimeos\MShop\Service\Provider\Decorator\Base::__construct(Aimeos
\MShop\Service\Provider\Iface $provider, Aimeos\MShop\Context\Item\Iface $context, Aimeos\MShop\Service
\Item\Iface $serviceItem) must be compatible with Aimeos\MShop\Service\Provider\Factory\Iface::__construct
(Aimeos\MShop\Context\Item\Iface $context, Aimeos\MShop\Service\Item\Iface $serviceItem) in <b>/html
/typo3/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-core/lib/mshoplib/src/MShop/Service/Provider
/Decorator/Base.php</b> on line <b>247</b><br />
With php 5.6.3 the last error message about the fatal error is missing.
Regards
trimble
Regards
trimble
- error_messages.png (8.84 KiB) Viewed 5727 times
It's better to fix the underlying problem than to try to work around it.trimble wrote: with the extension sourceopt I could clean the FE code. As result I get same errors but another output 'return window.wrappedJSObject || window;'
You need at least PHP 7.0.3 that fixes the problem: https://bugs.php.net/bug.php?id=71248trimble wrote: <b>Fatal error</b>: Declaration of Aimeos\MShop\Service\Provider\Decorator\Base::__construct) must be compatible with Aimeos\MShop\Service\Provider\Factory\Iface::__construct()
