Catalog Filter Problem
Assume that you have searched for "Column" via Catalog Filter Search. After searching, if you click any catalog link in the catalog filter tree, you receive Page Not Found error.
"Page Not Found
Reason: Segment "Column" was not a keyword for a postVarSet as expected on page with id=57."
(id=57, the id of the page on where Catalog List subpart added)
"Page Not Found
Re: Catalog Filter Problem
Can you give us a bit more details about the context of the problem, maybe with a screenshot? Do you use own RealUrl rules?
