Prices set in backend are not displaying in the front end
Hello, after setting up new products in the admin backend the prices are not displaying in the list page, this also makes it so i cannot add the item to cart. Any idea how i might fix this. Also how might i reset the database so there is no demo data anymore?
PS: I already disabled caching in the shop.php file and still no prices visible
Re: Prices set in backend are not displaying in the front en
Can you post a screenshot of the frontend and the price setup in the admin backend for this product?
Here are the pics
- back.PNG (44.26 KiB) Viewed 4729 times
- front.PNG (108.27 KiB) Viewed 4729 times
As you can see only EUR currency shows up.
Also while i have your attention which CSS file do edit to change styles? i see alot of them name the same and none of which seem to change any styles from their defaults
I think your first site/language/currency combination in the "Locale" tab (expert mode) is "default/en/EUR" instead of "default/en/USD".
To adapt the theme, please read these articles: https://aimeos.org/docs/Laravel#Themesafoster009 wrote:Also while i have your attention which CSS file do edit to change styles? i see alot of them name the same and none of which seem to change any styles from their defaults
Im not sure where the option to set default currency is but by the looks of it, it is enabled.
below is a picture
below is a picture
- locale.PNG (79.03 KiB) Viewed 4707 times
In the "List" tab, the default/en/USD combination must be at the first position for being the default one shown.
Thank you, it now appears to be working.
