Search Filter
Search Filter
I have included the search filter. How can i configure the search as global search, means searching in all produkt categories? And how can i activate the search suggestion?
Re: Search Filter
By default, the full text search is not category dependent. This can be changed by this configuration option:
https://aimeos.org/docs/Configuration/C ... rce-search
For the suggestions, you have to make sure that the catalog filter plugin contains the reference to the page in the flexform which only contains the catalog suggest plugin.
Re: Search Filter
The filter references to the search page with the suggest plugin. When typing in the search input, get request json data sucessfull but get no suggest-list. The ul stays emtpy.aimeos wrote:By default, the full text search is not category dependent. This can be changed by this configuration option:
And when clicking on search button, i get the information that there is no search result.
Re: Search Filter
What data is returned by the AJAX request?
Re: Search Filter
It returns an div containing the jsonaimeos wrote:What data is returned by the AJAX request?
<div id="c813" class="">
[{"id":1366,"name":"Kabelschelle sRF C\/ 1 x 7, f\u00fcr 6-7 mm Kabel"},{"id":1365,"name":"Kabelschelle sRF C\/ 1 x 8, f\u00fcr 7-8 mm Kabel"},{"id":1360,"name":"Kabelschelle sRF B\/ 2 x 8, f\u00fcr 7-8 mm Kabel"},{"id":1359,"name":"Kabelschelle sRF B\/ 2 x 12, f\u00fcr 11-12 mm Kabel"},{"id":1358,"name":"Kabelschelle 24 AC-E, f\u00fcr 20-24 mm Kabel"},{"id":1354,"name":"Kabelschelle 40 AC-E, f\u00fcr 36-40 mm Kabel"},{"id":1353,"name":"Kabelschelle 12\/2 AC-E, f\u00fcr 8-12 mm Kabel"},{"id":1352,"name":"Kabelschelle 12\/2 AC-E, f\u00fcr 8-12 mm Kabel"},{"id":1350,"name":"Kabelschelle sRF D\/ 1 x 1\/2\", f\u00fcr 16-17 mm Kabel "},{"id":1349,"name":"Kabelschelle sRF D\/ 1 x 5\/8\", f\u00fcr 21-23 mm Kabel"},{"id":1347,"name":"Kabelschelle sRF C\/ 3 x 5\/8\", f\u00fcr 21-23 mm Kabel"},{"id":1345,"name":"Kabelschelle sRF B\/ 1 x 7\/8\", f\u00fcr 27-28 mm Kabel"},{"id":1343,"name":"Kabelschelle OX C \/ 3 x 22, f\u00fcr 12-22 mm Kabel"},{"id":1342,"name":"Kabelschelle sRF B\/ 2 x 5\/8\", f\u00fcr 21-23 mm Kabel"},{"id":1341,"name":"Kabelschelle sRF B\/ 3 x 5\/8\", f\u00fcr 21-23 mm Kabel"},{"id":1337,"name":"Kabelschelle sRF E\/ 12 x 11, f\u00fcr 10-11 mm Kabel"},{"id":319,"name":"Kabelschelle sRF C\/ 2 x 11, f\u00fcr 1\/4\" Kabel, f\u00fcr C-Profilschiene 40 x 22 mm"},{"id":305,"name":"HF Kabel SMA -N RG223 \/ RG58 1m"},{"id":298,"name":"Erdungsschelle f\u00fcr 1\/4\", 3\/8\" und RG8 Kabel"},{"id":229,"name":"Kabelschelle sRF C\/ 1 x 11, f\u00fcr 1\/4\" Kabel, f\u00fcr C-Profilschiene 40 x 22 mm"},{"id":1291,"name":"Schnapp-Deckel KBS 600 mm f\u00fcr Kabelbahn, tauchfeuerverzinkt"},{"id":1289,"name":"Schnapp-Deckel KBS 400 mm f\u00fcr Kabelbahn, tauchfeuerverzinkt"},{"id":1290,"name":"Schnapp-Deckel KBS 500 mm f\u00fcr Kabelbahn, tauchfeuerverzinkt"},{"id":1288,"name":"Schnapp-Deckel KBS 300 mm f\u00fcr Kabelbahn, tauchfeuerverzinkt"},{"id":1287,"name":"Schnapp-Deckel KBS 200 mm f\u00fcr Kabelbahn, tauchfeuerverzinkt"}]
</div>
Re: Search Filter
You are using bootstrap_package 7.0.x which doesn't work because it's buggy and adds an additional <div></div> around the content. Please use bootstrap_package 6.2.x instead.
Re: Search Filter
i found an solution by removing the wrapper in the fluid layout and setting layoutsRootPath for fluidContent. But when clicking on a search suggestion the search result is empty- message no match.aimeos wrote:You are using bootstrap_package 7.0.x which doesn't work because it's buggy and adds an additional <div></div> around the content. Please use bootstrap_package 6.2.x instead.
Re: Search Filter
Can you post a screenshot of the suggestions? Maybe the MySQL full text search has a problem with the data.
Re: Search Filter
Here the screens:aimeos wrote:Can you post a screenshot of the suggestions? Maybe the MySQL full text search has a problem with the data.
- Bildschirmfoto 2016-05-12 um 12.08.44.png (37.88 KiB) Viewed 4521 times
- Bildschirmfoto 2016-05-12 um 12.08.29.png (124.34 KiB) Viewed 4521 times
Re: Search Filter
In the next major version, clicking on a suggest item will display the detail view for this product directly.
We are still investigating how to modify the MySQL full text search to get a useful result list for your case and will create a new minor release afterwards.
