Aimeos Multishop
Aimeos Multishop
I am trying to make a multishop system under same url but i am facing a problem i do the following steps in my typo3 instance and follow the steps written in aimeos mutishop documentation. https://aimeos.org/docs/TYPO3/Configure ... e_shops/en . please suggest me solutions.
- here you can see the status is enabled.
- Screenshot_3.png (18.42 KiB) Viewed 2717 times
- i have written these two lines in typoscript setup file
- Screenshot_2.png (74.43 KiB) Viewed 2717 times
- t5his is the error which i am getting in frontend.
- Screenshot_1.png (67.75 KiB) Viewed 2717 times
Re: Aimeos Multishop
Please give us a few more details about your installation.
At least TYPO3 and Aimeos version are required.
TYPO3 version is 6.2.12 and aimeos_16.4.3
Did you've added at least one valid site/language/currency combination in the Locale -> List tab for your "foodcart" site?
Thank you. I changed the locale->list currency,language combination according to you and it works correctly.
