Attribute radio or select
this settings has no effect in the Product Detail Page
i wrote this in the TypoScript Setup and in the TypoScript Configuration of the Catalog Detail Plugin.
The option of attributes should be a radio selection.
What else can i try?
Aimeos 16.4.3
Typo3 6.2
Thank you!
client.html.catalog.detail.basket.selection.type (
width = select
color = radio
option = radio
Aimeos 16.4.3
Typo3 6.2
Thank you!
Re: Attribute radio or select
Did you clear the frontend cache afterwards or disabled caching in the Extension Manager during development?
Hello, thank your for answer.
Yes, i clear the Frontend cache automatically after i did changes in Typo3 Backend .
Now i had disabled the cache in Extensionmanager in the Aimeos Shop Extension with "None" in the offered field, cleared cache in Install Tool "important actions --> Clear all cache"... Detail view is still showing select boxes for attributes.
Your TypoScript is wrong. You have to use braces - "{" and "}" - instead of brackets "(" and ")"alpin3rocker wrote:Code: Select all
client.html.catalog.detail.basket.selection.type ( width = select color = radio option = radio )
i found it out for myself.
now it works for selection type option i use following lines
but the attribute type (color) is still a selectbox with another design !?
Is it possible to get the first option checked per default?
thank you
plugin.tx_aimeos.settings.client.html.catalog.detail.basket.selection.type.option = radio
plugin.tx_aimeos.settings.client.html.catalog.detail.basket.attribute.type.color = radio
thank you
- aimeos-attribute-type.jpg (50.33 KiB) Viewed 2995 times
No, it's a radio checkbox now even if it doesn't look like at the first glimpsealpin3rocker wrote:but the attribute type (color) is still a selectbox with another design !?
Not yet, but in the next version this will be a configuration option.alpin3rocker wrote:Is it possible to get the first option checked per default?
