Installed aimeos with laravel, screen stuck at Expert mode.
I am new to laravel and aimeos, I have installed aimeos and navigated to admin after setting credentials for admin. There I got Expert mode, and after clicking on that a Loading... message appeared which is continuing from almost an hour... Am I missing something? Please help.
Re: Installed aimeos with laravel, screen stuck at Expert mo
Open the network console of your browser and have a look if requests are failing.
Hey, Thanks, wasn't expecting a quick reply.
Well I cannot see any errors on network panel of both chrome and firefox. However for 2 css files 404 is being thrown.
Also on chrome's console "extadm:1 Uncaught SyntaxError: Unexpected token <" this error i can see.
Thanks.
Thanks.
Which files are not found?HimanshuBhandari wrote:Well I cannot see any errors on network panel of both chrome and firefox. However for 2 css files 404 is being thrown.
Please have a look into the requests loading .js files and post the content of the request that starts with HTML ("<").HimanshuBhandari wrote:Also on chrome's console "extadm:1 Uncaught SyntaxError: Unexpected token <" this error i can see.
For these 2 I am getting 404 error :
http://localhost:8000/packages/aimeos/s ... 1468657054"
Re "failing requests in network tab" : I don't understand how to check for requests, but apart from above I couldn't find any error. I am attaching screen shots of both chrome and FF net tab.[img] [/img][img] [/img]
What is returned by the last "file?site=default" POST request?
Is that way you wanted? attached screen shot.
Thanks.
Thanks.
- aimeos_err3.png (78.2 KiB) Viewed 5181 times
Yes and it states exactly your problem:
The PHP option "always_populate_raw_post_data" must be set to "-1" in your configuration.
AMAZING!! This worked Thanks for the help. I avoided this configuration being a warning.
Its there any way that I can add custom features to the main menu tab. For example can I create my own 'Tracking' tab similar to the Overview or Product tab that came in the Expert mode when I login to the admin page
- I am also new to Aimeos.
