Installation problem on TYPO3 7.6.10 - Aimeos 16.7.0
Hello, I've got problems in installing Aimeos 16.7.0 on my TYPO3 7.6.10 (on Windows - XAMPP)
1) I installed the ext, executed the upgrade script (all "OK" and "done") but
- in install tool, it seems that all the tables were not added to the TCA
2) I also tried to import the pages from the link https://aimeos.org/fileadmin/download/A ... s_16.1.t3d
- when I go to the page "products" I got an error:
No value for key "filterHeader" found
Aimeos\MW\View\Exception thrown in file
C:\xampp\htdocs\www.teci.it.upgrade.bhuman.it\typo3conf\ext\aimeos\Resources\Libraries\aimeos\aimeos-core\lib\mwlib\src\MW\View\Standard.php in line 116.
(If needed I can provie a screenshot of the full error)
I don't know what goes wrong...can you help me? Thank you!
Re: Installation problem on TYPO3 7.6.10 - Aimeos 16.7.0
Another info: when I used the install tool > compare db to clean up everyting removing all DB fields, I got a series of errors like this:
Database update failed
Error: Cannot delete or update a parent row: a foreign key constraint fails
I had to use multiple times the compare db
1.) Aimeos don't use the TCA as it makes no sense for our tables (https://github.com/aimeos/aimeos-typo3/issues/7)
2.) Yes, the full stack trace would be helpful
3.) Aimeos makes heavy use of foreign key constraints for data integrity
