"No file was uploaded" after csv-import
hasmb
Post by hasmb » 27 Jul 2016, 15:59
I get "No file was uploaded" messages after importing from csv-file. Afterwards there are db entries for images but preview etc is broken.
I believe the images located in an "images" subdir of the import-dir are not found.
How do I have to write the "'media.url', // relative URL of the product image on the server" like stated in the docs?
- relative to what?
- leading "/"?
I used "images/FILENAME.jpg"
Thanks for any hints!
Re: "No file was uploaded" after csv-import
Post by aimeos » 27 Jul 2016, 23:17
You've used the product CSV importer?
https://aimeos.org/docs/Developers/Cont ... s_from_CSV
Images are relative to the content baseurl:
https://aimeos.org/docs/Configuration/C ... nt/baseurl
For TYPO3 it's set to ./uploads/tx_aimeos/ by default
hasmb
Post by hasmb » 28 Jul 2016, 13:04
Yes, I use the CSV importer.
I changed the location of the files. Works now.
Thank you!
