Empty error when using authorize.net AIM payment in test
i have attached a screenshot, what should i do now? that's a really frustrating error...
running 2016.7.2 in laravel aimeos and ai-payments 2016.7.2. I ran it locally and I ran it as well on a testserver in the internet. It's an authorize.net test account and I used a test visa credit card, tried test mastercard as well.
I use php 7
some ideas where I should be heading now? where to search?
I use php 7
- error_authorize_net_aim_payment.jpg (62.43 KiB) Viewed 2043 times
Re: Empty error when using authorize.net AIM payment
I am still stuck with an error, but now I at least found it
the way to access the error message was this:
in file
the response message should be retrieved like this, if the response message is empty that is:
$response->getData()->messages->message->code->__toString()
$response->getData()->messages->message->text->__toString()[/code]
now I would create a pull request if i knew how. I really would.
The error reads like this:
at least now I am stuck with a proper error...
in file
ff-laravel/ext/ai-payments/lib/custom/src/MShop/Service/Provider/Payment/OmniPay.php
at line 708 before
[code] throw new \Aimeos\MShop\Service\Exception( $response->getMessage() );
E00007
User authentication failed due to invalid authentication values.
hours later...
now I found in the interwebs that one has to regenerate the transaction Key. That is possible when logging in to authorize.net and then doing the change there, note: the answer to the security question for me was Simon and is called "Secret key" in the login creds they give you.
This did not solve my problem though (or i at least guess, that it was not part of the solution)
but something else...
is it eventually possible there is a mistake in the docs?
https://aimeos.org/docs/User_Manual/Adm ... ze.net_AIM
lists
this _seems_ to be wrong.
What I ended up doing when looking at the code I figured out there is:
so i added
in the configuration. This seems to work.
this changes the endpoint to apitest.authorize.... instead of the live one. basically, that is, i think, what should have been set with `authorizenet.testmode`
shit man, what, like 2 hours of my life for this.
there is as well:
i am not sure what it does. developerMode is what makes things work in sandbox
I found this note:
in
folder:
so maybe you can send test requests to the live account, maybe thats what it is good for.
lists
authorizenet.testmode (boolean, optional)
Use "1" for test payments without real money
developerMode
developerMode 1
there is as well:
testMode
I found this note:
// The test mode setting indicates whether or not this is a live request or a test request
AIMAbstractRequest.php
ff-laravel/vendor/omnipay/authorizenet/src/Message/AIMAbstractRequest.php
