Upload PNG Problem
Upload PNG Problem
I'm trying to add catalogs in aimeos all is fine but when i try to add a media in the catalog i get Upload Failed (undefined) i tried to upload jpg and png images and i got same error.
Re: Upload Failed (undefined)
When i removed the debugger from the config all goes fine but when i upload a png image with transparency it replace the transparency with a color (white or yellow or black it depends on the image) does anyone faced this problem
This is a screen shot about the image i'm trying to upload and the result when i upload it via aimeos
- Untitled-1.jpg (95.63 KiB) Viewed 2771 times
Re: Upload PNG Problem
The problem was solved when adding this row in save function:
imagesavealpha($this->image, TRUE);
This has been fixed three weeks ago and it should be already in the 2016.07.2 stable release
