Basket checkout : Cannot Populate default states list
Hi Aimeos,
I am using TYPO3 AIMEOS version 16.7 (latest from TER) working with default data. But in checkout process i would like to insert state as mandatory.
I did so using reference link : https://aimeos.org/docs/TYPO3/Configure ... ons_states
But the state select box doesn't contain any data.
I have seen there is a way to insert state data using TYPOSCRIPT : https://aimeos.org/docs/TYPO3/Configure ... nd_Regions.
But I need all the states adding manual is not possible in this case.
Please suggest me a way by which i can get all default data .
Thanks in Advance
Nageshwar Jha
Thanks in Advance
Nageshwar Jha
Re: Basket checkout : Cannot Populate default states list
Sorry, but there's no default data for states. Only a few countries need the state for a full address (US for example).
