Delivery costs multiply with weight or quantity?
Is it possible to multiply the delivery costs with the quantity or the weight?
Because our product's delivery cost basically depend upon the quantity / weight.
If not I guess it is relatively simple to add this feature by using a decorator.
Re: Delivery costs multiply with weight or quantity?
The "Weight" decorator for the service providers can do that:
https://github.com/aimeos/aimeos-core/b ... Weight.php
If it doesn't exactly fit your needs, you can create your own one based on the current implementation.
