Show custom in payment provider process()
brunojti
Post by brunojti » 26 Aug 2016, 15:12
Using the following code I was able to show an example form field for user input after the user confirms the summary data.
 public function process(\Aimeos\MShop\Order\Item\Iface $order, array $params = array())
        $list = array(
            'myprovider.accountno' => new \Aimeos\MW\Criteria\Attribute\Standard( array(
                'label' => 'Account number',
                'code' => 'myprovider.accountno',
                'internalcode' => 'myprovider.accountno',
                'internaltype' => 'string',
                'type' => 'string',
                'default' => '',
                'public' => true,
        $gatewayUrl = $this->getConfigValue(array('payment.url-self'));
        return new \Aimeos\MShop\Common\Item\Helper\Form\Standard($gatewayUrl, 'POST', $list);
I would need to have more control over this template, add HTML and Javascript for allowing the User to choose payment method and provide the payment data.
I'll also need to get some values by ajax before confirming the payment. I already have a `App\Http\Controllers\AjaxController` that handles the ajax requests...
How can I do this? Thanks
Re: Show custom in payment provider process()
Post by aimeos » 26 Aug 2016, 16:56
You can adapt the payment page template as you like for your project:
https://github.com/aimeos/ai-client-htm ... efault.php
brunojti
Post by brunojti » 26 Aug 2016, 17:14
I have skipped that page from checkout process, the page I am talking about is the page after summary...
EDIT: The file to edit is: `checkout/standard/order-body-default.php`.
I hope I'm not making anything wrong here =)
Post by aimeos » 26 Aug 2016, 17:45
You can adapt it's template as well:
