Remove countries from checkout in config/shop.php
Arthur Tarasov
Post by Arthur Tarasov » 28 Aug 2016, 13:24
Hi, I am trying to remove all countries except for a few from checkout address option. I do not want to tamper with core configuration and I am wondering if it is possible to do it in config/shop.php.
If I try the following, it just changes the first two countries in the list:
'client' => array(
		'html' => array(
			'checkout' => array(
	            'standard' => array(
	                'address' => array(
	                    'countries' => array(
	                    	'[0]' => 'US',
	                    	'[1]' => 'GB',
The following code appears to do nothing at all:
'client' => array(
		'html' => array(
	                'address' => array(
	                    	'US',
	                    	'GB',
What can I do if I just want those two countries to be available for users to select from?
Re: Remove countries from checkout in config/shop.php
Post by aimeos » 28 Aug 2016, 13:57
This works with the latest stable Aimeos core (2016.07.5)
Arthur Tarasov
Post by Arthur Tarasov » 29 Aug 2016, 08:49
I updated my shop to 2016.07 version but it still behaves the same way. The documentation shows it to be the latest stable version and it seems to risky to use dev versions for me.
What are my other options rather than altering `client/html/checkout/standard/address/countries`?
If I want to remove those countries within core library, where do I find the list of countries? The only file I found that has any list of countries is `..\vendor\aimeos\aimeos-core\client\i18n\country\core-client-country.pot`. Is this the file that I am trying to configure through shop.php? I was looking through the database for a table with countries, but I couldn't find it either.
Arthur Tarasov
Post by Arthur Tarasov » 30 Aug 2016, 02:36
I ended up changing the list of countries in
..\vendor\aimeos\aimeos-core\client\html\config\client.php
This only works in v 2016.04. I couldn't figure out how to do it in v 2016.07
Post by aimeos » 31 Aug 2016, 17:43
The problem is the "[0]" and "[1]":
Arthur Tarasov wrote:
'client' => array(
		'html' => array(
	                'address' => array(
	                    	'[0]' => 'US',
	                    	'[1]' => 'GB',
As it's a PHP array it must be
	                    	0 => 'US',
	                    	1 => 'GB',
Post by aimeos » 02 Sep 2016, 09:25
The Laravel integration didn't allow to overwrite a setting that contains a list of values up to now. They have been merged instead.
The latest release (2017.07.3) offers the same functionality as Symfony. You can add your countries to the config/shop.php file and only those will be displayed.
