Adding a Plug-in (Multiple Times)
Metalics
Post by Metalics » 06 Sep 2016, 13:03
Hello to all,
In catalog list page; If you add a plug-in 2 times, the TypoScript Configuration of the second one doesn't work.
For example i want to separate some parts of the Catalog Lists plug-in by using "subpart", and adding this plug-in 2 times in my catalog list page.
The TypoScript Configuration of the first added plug-in is:
plugin.tx_aimeos.settings.client.html.catalog.lists.standard.subparts {
0 = head
1 = quote
2 = promo
The TypoScript Configuration of the second added plug-in is:
0 = pagination
1 = items
In this case, Aimeos doesn't respect the TypoScript Configuration of the second one. Am i missing something?
Re: Adding a Plug-in (Multiple Times)
Post by aimeos » 06 Sep 2016, 13:05
We have one similar setup which works fine. Which Aimeos version do you use?
Metalics
Post by Metalics » 06 Sep 2016, 14:43
Aimeos: 16.7.1
Typo3: 7.6.10
Post by aimeos » 06 Sep 2016, 15:53
Tried that with both, 16.7.1 and the latest code and it works as expected if I enter the first configuration into the TSConfig field of the first plugin and do the same for the second one.
Most likely, your second TypoScript contains a character which the TS-Parser doesn't like. In this case, the configuration is ignored.
