.po file
wenotine
.po file
Post by wenotine » 19 Sep 2016, 15:21
Thank you again for your last help, now we are working on the language file.
I saw your documentation and checked Transifex.
I found the .po languge files, but if I change any words on the file, nothing happening on the site.
How can I add the .po files or how can I generate the language from the .po file?
I saw that it uses the mo.php, but dont understand what to do...
Thank you!
Re: .po file
Post by aimeos » 19 Sep 2016, 15:37
Translate the strings at Transifex. We will update dev-master and generate the necessary files afterwards.
wenotine
Re: .po file
Post by wenotine » 26 Sep 2016, 08:24
Thank you for your help again.
We finished the translation to Hungarian(hu) language on transiflex, please install the language file, and let me know what I have to do to reach it.
Thank you!
Re: .po file
Post by aimeos » 26 Sep 2016, 09:59
Great! Thank you very much! :-)
We've updated the dev-master branch so you will get the new translations if you change your composer.json to use dev-master for the Aimeos packages and do a "composer update" afterwards.
nora1984antal
Re: .po file
Post by nora1984antal » 28 Sep 2016, 12:53
We've already seen the Hungarian(hu) translation after the composer update. Thank you. We've updated some text in the translation on Transifex.
Please, update them in the dev-master.
thank you
Re: .po file
Post by aimeos » 29 Sep 2016, 07:52
Thank you for the translations. They have been updated in dev-master.
nora1984antal
Re: .po file
Post by nora1984antal » 30 Sep 2016, 08:18
we've found another mistakes so we've updated the translation again. Please, update them in the dev-master.
Thank you
nora1984antal
Re: .po file
Post by nora1984antal » 18 Oct 2016, 07:37
Hello aimeos,
there are a lot of changes in the hungarian translation, and we don't see them in the last update. We need the corretc translations so please update them. And we would like to know that the aimeos version 2016.10 consists the last translations or only the dev version does.
Thank you
Re: .po file
Post by aimeos » 19 Oct 2016, 16:53
The translations are now up to date in the dev-master and 2016.10 branch. They will be available via composer with the next minor releases.
