Limit Product Search Suggestion to Product 'Selection' only?
Re: Limit Product Search Suggestion to Product 'Selection' o
The only thing I tried to fix the problem is this:aimeos wrote:Yes, it is. I assume you haven't added any configuration to your config/shop.php file that includes an "index" part?
'mshop' => [
'index' => [
'manager' => [
'attribute' => [
'standard' => [
'search' => [
'mysql' =>
'SELECT mpro."id"
FROM "mshop_product" AS mpro
:joins
WHERE :cond
GROUP BY mpro."id" /*-orderby*/, :order /*orderby-*/
/*-orderby*/ ORDER BY :order /*orderby-*/
LIMIT :size OFFSET :start'
It took us some time to figure out what the problem was.
If you save an article of a selection product in the expert mode admin interface, the product is added to the index regardless of being associated to a category. This is fixed in the dev-master branch of the Aimeos core now.
You should run "composer update" and delete all entries in the "mshop_index_text" table. Then, start the index rebuild with "./artisan aimeos:jobs index/rebuild". If you now save articles that should be part of a selection product and containing a text of type "name", than they shouldn't be indexed any more.
Thanks for your help. The latest Aimeos-core dev update really solved the issue.
My search suggestion is working properly now
