Change EXT:aimeos_dist/Resources/Private/Partials/Page/
Sorry if this too basic, I'm very new to Aimeos.
I cannot change this path: EXT:aimeos_dist/Resources/Private/Partials/Page/
to fileadmin/dir/dir/page
or to any other path.
Normally this is a straight forward task overriding the fluidtemplate paths, but with Aimeos I am stuck.
Where do I make the changes?
I want to customize the navigation "Main.html" template.
Many thanks,
Regards,
Tony
Many thanks,
Regards,
Tony
Re: Change EXT:aimeos_dist/Resources/Private/Partials/Page/
The TS constant configuration contains this setting:
You can copy the directory structure to another place and change it accordingly
page.fluidtemplate.partialRootPath = EXT:aimeos_dist/Resources/Private/Partials/Page/
Thank you for the answer. I have corrected my link.
Before I had tried this: page.fluidtemplate.partialRootPath = fileadmin/aimeos_dist/Resources/Private/Page/
I have changed my local directories to reflect the aimeos_dist structure, I put "Partials" in the path, now it works:
page.fluidtemplate.partialRootPath = fileadmin/aimeos_dist/Resources/Private/Partials/Page/
Thanks again,
Regards,
Tony
Thanks again,
Regards,
Tony
