Error /list data: Locale item for site "default" not found
hernandezfo
Post by hernandezfo » 30 Sep 2016, 23:15
Hi I just installer aimeos using laravel 5.2, but when I try to browse the catalog list page:
http://127.0.0.1:8000/index.php/list
I am getting this error:
Exception in Standard.php line 518:
Any ideas?
Thanks in advance
Re: Error /list data: Locale item for site "default" not fo
Post by aimeos » 02 Oct 2016, 15:18
Your database doesn't contain some records for an unknown reason. You can execute
./artisan aimeos:setup --option=setup/default/demo:1
again to add the missing entries.
Post by aimeos » 03 Oct 2016, 09:11
You get this error if the locale site entry is disabled. To enable it, go to the admin interface (expert mode) and change the status to "available" in the Locale -> Site tab.
Austinjay
Post by Austinjay » 18 Oct 2016, 17:07
aimeos wrote:You get this error if the locale site entry is disabled. To enable it, go to the admin interface (expert mode) and change the status to "available" in the Locale -> Site tab.
Please how do i access the admin interface or the expert mode in order to chabge the status
Post by aimeos » 19 Oct 2016, 13:55
You need an admin account you can create with
php ./artisan aimeos:account --admin <email>
