Import from csv
Import from csv
Dear Aimeos support, thank you for your excelent job, right now, we need You again
We have our csv, where the products are different by size or by color.
Product code label color size
118391-56 4 Bourke vibrant green 2 size XL
118391-56 5 Bourke vibrant green 2 size XXL
118391-57 4 Bourke pirate black 2 size XL
118391-57 5 Bourke pirate black 2 size XXL
We use this import:
'mapping'=> array(
'item' => array(
1 => 'product.label', // UTF-8 encoded text, also used as product name
2 => 'product.type', // type of the product, e.g. "default" or "selection"
3 => 'product.status', // enabled (1) or disabled (0)
'text' => array(
4 => 'text.languageid',
5 => 'text.type', // e.g. "short" for short description
6 => 'text.content', // UTF-8 encoded text
7 => 'text.languageid',
8 => 'text.type', // e.g. "short" for short description
9 => 'text.content', // UTF-8 encoded text
10 => 'text.languageid',
11 => 'text.type', // e.g. "long" for long description
12=> 'text.content', // UTF-8 encoded text
'media' => array(
13 => 'media.url', // relative URL of the product image on the server
'price' => array(
14 => 'price.currencyid',
15 => 'price.quantity', // the quantity the price is valid from (for block pricing)
16 => 'price.value', // price with decimals separated by a dot, no thousand separator
17 => 'price.rebate',
18 => 'price.taxrate', // tax rate with decimals separated by a dot
'stock' => array(
19 => 'product.stock.stocklevel',
20 => 'product.stock.warehouse',
// 2 => 'product.stock.warehouseid',
// 3 => 'product.stock.dateback',
'catalog' => array(
21 => 'catalog.code', // e.g. Unique category code
// 21 => 'catalog.list.type', // e.g. "promotion" for top seller products
'attribute' => array(
22 => 'attribute.typeid',
23 => 'attribute.type',
24 => 'attribute.code',
25 => 'attribute.label',
26 => 'attribute.position',
27 => 'attribute.status',
28 => 'attribute.typeid',
29 => 'attribute.type',
30 => 'attribute.code',
31 => 'attribute.label',
My question is:
How can we have a base product and plus four variant?
- we need a base product with short and long description, price etc. (No. zero line in the csv)
- and we need 4 variants
first variant: color: vibrant green, size: XL
second: variant: color: vibrant green, size: XXL
third: variant: color: pirate black, size: XL
fourth: variant: color: pirate black, size: XXL
Please let me know what to do.
Thank you
We use this import:
'mapping'=> array(
'item' => array(
'text' => array(
'media' => array(
'price' => array(
'stock' => array(
'catalog' => array(
My question is:
Thank you
Re: Import from csv
First, add a product line with product item type "selection" to your CSV file and add the texts too. Then, add four product list of type "default" (articles) to the CSV file, which also contains the variant attributes. Configure your mapping to assign the attributes with product.list.type "variant" and to assign the articles to the selection product via the unique product.code for the selection product.
In your mapping, you need for the "attribute" section a column for the product.list.type (value: "variant") and another section named "product" with the product code of the selection product the article belongs to. Remove the "attribute.typeid" column and it's mapping because you already have "attribute.type".
Re: Import from csv
Hi mr Aimeos!aimeos wrote:First, add a product line with product item type "selection" to your CSV file and add the texts too. Then, add four product list of type "default" (articles) to the CSV file, which also contains the variant attributes. Configure your mapping to assign the attributes with product.list.type "variant" and to assign the articles to the selection product via the unique product.code for the selection product.
Thanks for answer!
Wwe modified our mapping by your advice like this:
'mapping'=> array(
'item' => array(
'text' => array(
'media' => array(
'price' => array(
'stock' => array(
'catalog' => array(
22 => 'attribute.type',
23 => 'attribute.code',
24 => 'attribute.label',
25 => 'attribute.position',
26 => 'attribute.status',
27 => 'attribute.type',
28 => 'attribute.code',
29 => 'attribute.label',
30 => 'product.list.type',//variant?
'product' => array(
31 => 'product.code', // e.g. EAN code of another product
(there are a select product in the first line with texts and main parameters and price, and 2 variant for now with different size types with same color attributes and different stock levels)
"118391-298756",Bourke,select,1,hu,name,Bourke,hu,short,"Fundango, 100% poliészter vízálló, lélegző alapanyagú levehető kapucnis kabát hegesztett varratokkal a kritikus helyeken. Laminált zsebfedős zsebekkel, belső zsebbel, szemüveg tartó zsebbel, hófogóval. Szellőző kialakítással. Cipzárral rögzíthető a nadrágokhoz.",hu,long,"Fundango, 100% poliészter vízálló, lélegző alapanyagú levehető kapucnis kabát hegesztett varratokkal a kritikus helyeken. Laminált zsebfedős zsebekkel, belső zsebbel, szemüveg tartó zsebbel, hófogóval. Szellőző kialakítással. Cipzárral rögzíthető a nadrágokhoz.",http://www.dockyard.hu/media/catalog/product/1/Q/1QL102_538_1_1.jpg,HUF,1,19990,17000,27,,default,m-coats,,,,,,,,
"118391-298756 2","Bourke green",default,1,hu,name,"Bourke green",,,,,,,,,,,,,4,default,m-coats,color,538,"vibrant green",size,XXL,XXL,variant,"118391-298756"
"118391-298756 3","Bourke green",default,1,hu,name,"Bourke green",,,,,,,,,,,,,2,default,m-coats,color,538,"vibrant green",size,XL,XL,variant,"118391-298756"
We tried to delete the name and label from variants but doesnt work too (name can be same too but somehow we have to different them in the admin)
My question is aour mapping are good? and what we had wrong on the csv file?
Re: Import from csv
What's the error that occurs?
Re: Import from csv
Position 25 and 26 of your mapping are definitively wrong according to your CSV file:
If color is also something that can have different values, then there should be a "variant" column and a product.lists.type mapping too.
Re: Import from csv
aimeos wrote:Position 25 and 26 of your mapping are definitively wrong according to your CSV file:If color is also something that can have different values, then there should be a "variant" column and a product.lists.type mapping too.Code: Select all
25 => 'attribute.position', 26 => 'attribute.status',
Hi thank you for answer!
-we get steps forward but we have question to finish our importer.
Our modified mapping is here:
'mapping' => array(
'item' => array(
1 => 'product.code', // e.g. unique product code from erp
2 => 'product.label', // UTF-8 encoded text, also used as product name (common in variants)
3 => 'product.type', // type of the product, e.g. "default" or "selection"
4 => 'product.status', // enabled (1) or disabled (0)
'text' => array(
5 => 'text.languageid',//(common in variants)
6 => 'text.type', // e.g. "short" for short description(common in variants)
7 => 'text.content', // UTF-8 encoded text(common in variants)
8 => 'text.languageid',//(common in variants)
9 => 'text.type', // e.g. "short" for short description(common in variants)
10 => 'text.content', // UTF-8 encoded text(common in variants)
11 => 'text.languageid',//(common in variants)
12 => 'text.type', // e.g. "long" for long description(common in variants)
13 => 'text.content', // UTF-8 encoded text(common in variants)
'media' => array(
14 => 'media.url', // relative URL of the product image on the server
'price' => array(
15 => 'price.currencyid',//(common in variants)
16 => 'price.quantity', // the quantity the price is valid from (for block pricing)(common in variants)
17 => 'price.value', // price with decimals separated by a dot, no thousand separator (common in variants)
18 => 'price.rebate',// (common in variants)
19 => 'price.taxrate', // tax rate with decimals separated by a dot (common in variants)
'stock' => array(
20 => 'product.stock.stocklevel', // (various in variants)
21 => 'product.stock.warehouse', //(common in variants)
22 => 'product.list.type',//variant?
23 => 'attribute.type',//(common in variants)
24 => 'attribute.code',// (various in variants)
25 => 'attribute.label',// (various in variants)
//25 => 'attribute.position',
// 26 => 'attribute.status',
26 => 'product.list.type', //variant?
27 => 'attribute.type',//(common in variants)
28 => 'attribute.code',// (various in variants)
29 => 'attribute.label',// (various in variants)
'product' => array(
30 => 'product.list.type', //variant?
'catalog' => array(
32 => 'catalog.code',//(common in variants)
33 => 'catalog.code',//(common in variants)
34 => 'catalog.code',//(common in variants)
35 => 'catalog.code',//(common in variants)
36 => 'catalog.code',//(common in variants)
37 => 'catalog.code',//(common in variants)
'property' => array(
38 => 'product.property.type',//anyagosszetetel//(common in variants)
39 => 'product.property.value',//(common in variants)
40 => 'product.property.type',//cikkszam//(common in variants)
41 => 'product.property.value', //(common in variants)
,1QL102,Bourke,select,1,hu,name,Bourke,hu,short,"short text",hu,long,"long product text",path/to/image1.jpg,HUF,1,19990,17000,27,,default,,,,,,,,,,,man,1-si-es-snowboard-kabat,,,,,anyagosszetetel,"100% poliészter",cikkszam,1QL102
,118391-298756-4,Bourke,default,1,,,,,,,,,,path/to/image2.jpg,,,,,,3,default,variant,color,538,"vibrant green",variant,size,XL,XL,,1QL102,,,,,,,,,,
,118391-298756-5,Bourke,default,1,,,,,,,,,,path/to/image3.jpg,,,,,,4,default,variant,color,538,"vibrant green",variant,size,XXL,XXL,,1QL102,,,,,,,,,,
,118391-298757-4,Bourke,default,1,,,,,,,,,,path/to/image4.jpg,,,,,,9,default,variant,color,893,"pirate black",variant,size,XL,XL,,1QL102,,,,,,,,,,
So the products are in the database but products dosnt have connections to selection product.
From the other way The selection product doesnt have any variations.
I think i misunderstood something.
As you can see in the csv I tried to create a selection product in the first line how You said before, then i trying to import 3 lines with 3 variation of the selection product what was in the first line.
How can I fix this issue?
Second question is how can I add a variation to any existing selection product to the catalog by csvImport?
- csv imported products in extadm screenshot1
- csvimp1.jpg (179.44 KiB) Viewed 5242 times
Re: Import from csv
You should remove the first column and the first entry in the mapping (product.lists.type) because it's wrong there. You main problem is column 30 because it contains no value. Either you remove the column and it's mapping or you fill it with the value "default".
Re: Import from csv
I am having the same problem.
What me and Goerge were trying to accomplish is to
1. define a selection (unique ID "SEL123")
2. define all articles (default products) and link these articles with previously defined selection by mentioning a unique ID where these articles belongs to ("SEL123" in this case)
your examples use different logic. you first define all the articles and then you define selection and list all the article IDs that belongs to this selection.
and what I think is closer to the "real world" is what we are trying to do. usually you want to link children to the parent by providing parentID to all children. and not providing all children ID in one parent.
can you give us example how can we get this to work?
thanks.
thanks.
Re: Import from csv
You would have to implement a new import processor, e.g. named "selection" that is similar to the existing "product" one but does the reverse: Not linking articles to a selection product but looking up the selection product and create a link to the current article.
https://github.com/aimeos/ai-controller ... andard.php
Re: Import from csv
Thanks for the suggestion, I did and it works now.
