CSV Import file location setup issue?
alfredlaggner
Post by alfredlaggner » 12 Oct 2016, 03:36
I am working for the first time on a setup for importing product records with CVS. When I run
 php artisan aimeos:jobs product/import/csv
I get an error message: [Aimeos\Controller\Jobs\Exception]
Number of apostrophes don't match
I suspect the message is misleading and I am just not reading the the right file.
My store array has this for location:
'controller' => array(
        'jobs' => array(
            'product' => array(
                'import' => array(
                    'csv' => array(
                        'location ' => 'C:\Users\alfre\OneDrive\Websites\digital_ocean_procects\ga_delivery\storage\public\uploads\products.csv',
                        'skip-lines' => 1,
I know the CSV file is at this location. I export it with phpexcel for laravel.
One record looks like this:
"859162005091","","2","","long","Auntie Delores-Chili Lime Peanuts 50mg","strain","","","","","","","","","","","",""
I am using the default mapping. (I will fine tune it after I know I can import.
I looked at the log but I cannot make sense out of it. If you want I can send it to you.
Seperate question: where can I find the commands for the cron jobs. I found this one on this forum.
Any help is welcome!
Alfred
alfredlaggner
Re: Import location setup issue?
Post by alfredlaggner » 12 Oct 2016, 03:56
I have Laravel 5.3 PHP 7 and the latest Aimeos version.
(Tried to attach the log file but the extension was not allowing it (madmin_log.sql).
Re: CSV Import file location setup issue?
Post by aimeos » 12 Oct 2016, 19:20
Your problem is that you configured the CSV file but it needs to be a
- directory or
- zip or
- Excel file
depending on the configured type (https://aimeos.org/docs/Developers/Cont ... and_format)
Here are the available jobs:
https://aimeos.org/docs/Laravel/Configu ... jobs#Setup
alfredlaggner
Post by alfredlaggner » 13 Oct 2016, 04:57
Thank you for your help. But I am still stuck with setting up the location to read the import file. Can you give me an example? My file location is 'storage/public/uploads'. My import file is 'products.csv'. The file content is csv format.
How do I define this in the shop controller array?
When I ran the php artisan command I get output in my database. But the output is from reading the laravel .env file! Please help me out with a sample. I very much appreciate your help. I have already spent many hours trying to figure out this puzzle.
Post by aimeos » 13 Oct 2016, 11:47
Either create a directory which contains only the CSV file and use this configuration:
        'jobs' => array(
            'product' => array(
                'import' => array(
                    'csv' => array(
                        'location ' => storage_path( 'secure' ) . '\public\uploads',
                        'container' => array(
                            'type' => 'Directory',
                            'content' => 'CSV',
                        'skip-lines' => 1,
As alternative, you can upload a zipped CSV file and use this config:
        'jobs' => array(
            'product' => array(
                'import' => array(
                    'csv' => array(
                        'location ' => storage_path( 'secure' ) . '\public\uploads\products.zip',
                            'type' => 'Zip',
                            'content' => 'CSV',
                        'skip-lines' => 1,
alfredlaggner
Post by alfredlaggner » 14 Oct 2016, 00:05
Now I modified my shop controller like this:
      'controller' => [
        'jobs' => [
            'product' => [
                'import' => [
                    'csv' => [
                        'location' => storage_path('secure') . '/public/uploads',
                        'container' => [
                            'content' => 'CSV',
                        'skip-lines' => 1,
                        'mapping' => [
                            'item' => [
//                                1 => 'product.label', // UTF-8 encoded text, also used as product name
                                1 => 'product.type', // type of the product, e.g. "default" or "selection"
                                2 => 'product.status', // enabled (1) or disabled (0)
                            'text' => [
                                3 => 'text.type', // e.g. "short" for short description
                                4 => 'text.content', // UTF-8 encoded text
//                                6 => 'text.type', // e.g. "long" for long description
//                                7 => 'text.content', // UTF-8 encoded text
                            'media' => [
                                5 => 'media.url', // relative URL of the product image on the server
                            'price' => [
//                                9 => 'price.quantity', // the quantity the price is valid from (for block pricing)
                                6 => 'price.value', // price with decimals separated by a dot, no thousand separator
//                                11 => 'price.taxrate', // tax rate with decimals separated by a dot
                            'attribute' => [
                                7 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
//                                13 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
                            'product' => [
                                8 => 'product.code', // e.g. EAN code of another product
//                                15 => 'product.list.type', // e.g. "suggestion" for suggested product
//                            'property' => [
//                                16 => 'product.property.value', // arbitrary value for the corresponding type
//                                17 => 'product.property.type', // e.g. "package-weight"
//                            'catalog' => [
//                                18 => 'catalog.code', // e.g. Unique category code
//                                19 => 'catalog.list.type', // e.g. "promotion" for top seller products
My import csv looks like this:
"product.code","product.status","text1.type","text1.content","media.url","price.value","attribute.type","product.barcode"
"82","1","long","Auntie Delores-Chili Lime Peanuts 50mg","","10.00","weight","859162005091"
"110","1","long","Badfish-Afgoo Cheese","","10.00","weight",""
"9","1","long","Mixed","","10.00","weight",""
"90","1","long","Mixed","","10.00","weight",""
"112","1","long","Badfish-Apple Jack","","10.00","weight",""
"877","1","long","Super Jack-Preroll (King)","","10.00","weight",""
"4","1","long","250 mg Sweet and Sours","","10.00","weight",""
"265","1","long","Tiva Energy-Tangerine 120mg","","10.00","weight",""
"109","1","long","Badfish-Gorilla Glue #4","","10.00","weight",""
"107","1","long","Badfish-Mango","","10.00","weight",""
When I attempt to import I get this log entry for every record:
Unable to import product with code "82": No type item for "product/long" in "product/type" found
Can you please take a look and let me know what I do wrong?
Also how canI create a clean database after testing?
Thank you again for your help.
Post by aimeos » 15 Oct 2016, 12:17
You should first make sure that the correct file is used. For this, you should add some debug statements to the Aimeos code, e.g. at https://github.com/aimeos/ai-controller ... d.php#L430 and https://github.com/aimeos/ai-controller ... d.php#L339. You can find the files in the "./ext/ai-controller-jobs/" directory.
alfredlaggner
Post by alfredlaggner » 17 Oct 2016, 03:40
Thank you again for your support. with your help I figured out the previous problem.
Now there is a new obstacle:
After many cycles of uploads anf tryouts I suddenly got this error that I don't understand:
[Symfony\Component\Debug\Exception\FatalThrowableError]
Call to a member function fromArray() on null
It happened after I put price.currencyid to every price. When I reversed the change the error message remained.
"654","default","1","NY Sour Diesel-Preroll (King)","short","NY Sour Diesel-Preroll (King)","long","NY Sour Diesel-Preroll (King)","xxx","weight","default","USD","1","14","0.00","","","","","","","","",""
Here is my shop mapping:
                        'mapping' => [
                            'item' => [
                                3 => 'product.label', // UTF-8 encoded text, also used as product name
                            'text' => [
                            'media' => [
                                8 => 'media.url', // relative URL of the product image on the server
                            'attribute' => [
                                9 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
                            'price' => [
                                10 => 'price.type',
                                11 => 'price.currencyid',
                                12 => 'price.quantity', // the quantity the price is valid from (for block pricing)
                                13 => 'price.value', // price with decimals separated by a dot, no thousand separator
                                14  => 'price.taxrate', // tax rate with decimals separated by a dot
                                15 => 'price.quantity', // the quantity the price is valid from (for block pricing)
                                16 => 'price.value', // price with decimals separated by a dot, no thousand separator
                                17 => 'price.taxrate', // tax rate with decimals separated by a dot
                                18 => 'price.quantity', // the quantity the price is valid from (for block pricing)
                                19 => 'price.value', // price with decimals separated by a dot, no thousand separator
                                20 => 'price.taxrate', // tax rate with decimals separated by a dot
                                21 => 'price.quantity', // the quantity the price is valid from (for block pricing)
                                22 => 'price.value', // price with decimals separated by a dot, no thousand separator
                                23 => 'price.taxrate', // tax rate with decimals separated by a dot
 //                           'product' => [
//                                8 => 'product.code', // e.g. EAN code of another product
//                            'property' => [
//                            'catalog' => [
Alfred
Post by aimeos » 17 Oct 2016, 10:12
Your price mapping only contains the currencyid once but your mapping contains several prices. You need it for every price value you want to import.
alfredlaggner
Problem with price import
Post by alfredlaggner » 18 Oct 2016, 17:08
I went back to the manual and created a price mapping accordingly but I seem unable to get it to work.
Here is the manual excerpt:
The value, currencyid and type (or typeid) are required as the minimum amount of data.
I know it is the prices because import runs without them.
I have up to four prices per product. If there are fewer than four prices I create prices with price 0.00.I have a type and a currency with every price.
What am I missing? :? :?:
This is the error:
This is the import file:
"product.code","product.type","product.status","product.label","text1.type","text1.content","text2.type","text2.content","media.url","price.type0","price.currencyid0","price.quantity0","price.value0","price.type1","price.currencyid1","price.quantity1","price.value1","price.type2","price.currencyid2","price.quantity2","price.value2","price.type3","price.currencyid3","price.quantity3","price.value3"
"82","default","1","Auntie Delores-Chili Lime Peanuts 50mg","short","Auntie Delores-Chili Lime Peanuts 50mg","long","Auntie Delores-Chili Lime Peanuts 50mg","nothing","default","USD","1","9.22","default","USD","1","0.00","default","USD","1","0.00","default","USD","1","0.00"
This is the shop controller mapping:
'controller' => [
'jobs' => [
'product' => [
'import' => [
'csv' => [
'container' => [
'content' => 'CSV',
'skip-lines' => 1,
'mapping' => [
'item' => [
'text' => [
'media' => [
'price' => [
9 => 'price.type',
10 => 'price.currencyid',
11 => 'price.quantity', // the quantity the price is valid from (for block pricing)
12 => 'price.value', // price with decimals separated by a dot, no thousand separator
13 => 'price.type',
14 => 'price.currencyid',
17 => 'price.type',
18 => 'price.currencyid',
19 => 'price.quantity', // the quantity the price is valid from (for block pricing)
20 => 'price.value', // price with decimals separated by a dot, no thousand separator
21 => 'price.type',
22 => 'price.currencyid',
23 => 'price.quantity', // the quantity the price is valid from (for block pricing)Call to a me
24 => 'price.value', // price with decimals separated by a dot, no thousand separator
