Aimeos breaks the TYPO3 scheduler extension
Hi all
Im on the following installation and enviroment:
Linux, PHP 7.0.13, TYPO3 7.6.12 and aimeos 16.10.1
If I try to add a new task there's just an empty form (see attachement). Otherwise the scheduler works fine, I can still execute tasks but just not add new ones. If I deactivate the extension the scheduler works fine again.
I tried deactivating, deleting and reinstalling the extension, but that didn't help.
Does somebody have a clue why this could be happening?
- task.PNG (25.69 KiB) Viewed 2108 times
Re: Aimeos breaks the TYPO3 scheduler extension
Tested with PHP 7.0.8, TYPO3 7.6.11, Aimeos 16.10.1 and works as expected.
Are there any hints in the TYPO3 log, the Apache error log or the madmin_log table?
I used to get the following error in the TYPO3 log (but not anymore after deleting and reinstalling aimeos):
Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1: PHP Warning: file_exists(): open_basedir restriction in effect. File(/opt/php-7.0.13/lib/php/Admin/JsonAdm/Order/Factory.php) is not within the allowed path(s): (/var/www/clients/client1/web12/web:/var/www/clients/client1/web12/private:/var/www/clients/client1/web12/tmp:/var/www/test.domain/web:/srv/www/test.domain/web:/usr/share/php5:/usr/share/php:/tmp:/usr/share/phpmyadmin:/etc/phpmyadmin:/var/lib/phpmyadmin) in /var/www/clients/client1/web12/web/zwicky/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-core/Bootstrap.php line 80 | TYPO3\CMS\Core\Error\Exception thrown in file /var/www/clients/client1/web12/web/zwicky/typo3_src-7.6.12/typo3/sysext/core/Classes/Error/ErrorHandler.php in line 111. Requested URL: http://www.domain.test.xyz/typo3/index. ... it%5D=1000
Seems like Aimeos uncovers faulty PHP configurations
Same problem as before: Not all your directories in the PHP include path are allowed by your open_basedir configuration. This will lead to problems until both configurations are in sync.
It turned out that enabling debug mode in the Install tool together with Aimeos being installed caused Scheduler not to function correctly. I set my installation to Live mode and it works again.
