CSV Import file location setup issue?
Re: CSV Import file location setup issue?
Your baseurl seem to be somehow incorrect. The image source should start with "/" because your detail page ist /detail/.../0 and relative paths without leading slash will be fetched as /detail/.../0/files/...jpg
After doing other work I came back io import pictures. I corrected the baseurl by adding a leading backlash. But now I have a new issue: as you suggested I added the media file name to the csv import. But no matter what I try the filename does not show up within aimeos database system. I tried with typeid = 1 and without typeid. When I manually add an image in the database (just for testing) I get it to display correctly.
This is a step back from my previous attempt where the file name was accepted after import.
Again here are my configuration files and a sample for you to check. This version is without typeid and with media.preview.
Please advise! I am looking forward to your answer. I am using the latest uupdate of aimeos.
"26","default","1","Irie-Protein Bar 175mg","short","Irie-Protein Bar 175mg","long","Irie-Protein Bar 175mg","product","USD","","23","-15.25000000000022","product","USD","","","","product","USD","","","","product","USD","","","","9","1","7","2","protein bar irie.jpg","protein bar irie.jpg"
'mapping' => [
'item' => [
1 => 'product.type', // type of the product, e.g. "default" or "selection"
2 => 'product.status', // enabled (1) or disabled (0)
3 => 'product.label', // UTF-8 encoded text, also used as product name
'text' => [
6 => 'text.type', // e.g. "long" for long description
7 => 'text.content', // UTF-8 encoded text
'price' => [
8 => 'price.typeid',
9 => 'price.currencyid',
10 => 'price.quantity', // the quantity the price is valid from (for block pricing)
11 => 'price.value', // price with decimals separated by a dot, no thousand separator
12 => 'price.taxrate', // the quantity the price is valid from (for block pricing)
13 => 'price.typeid',
14 => 'price.currencyid',
15 => 'price.quantity', // the quantity the price is valid from (for block pricing)
16 => 'price.value', // price with decimals separated by a dot, no thousand separator
17 => 'price.taxrate', // the quantity the price is valid from (for block pricing)
18 => 'price.typeid',
19 => 'price.currencyid',
20 => 'price.quantity', // the quantity the price is valid from (for block pricing)
21 => 'price.value', // price with decimals separated by a dot, no thousand separator
22 => 'price.taxrate', // the quantity the price is valid from (for block pricing)
23 => 'price.typeid',
24 => 'price.currencyid',
25 => 'price.quantity', // the quantity the price is valid from (for block pricing)Call to a me
26 => 'price.value', // price with decimals separated by a dot, no thousand separator
27 => 'price.taxrate', // the quantity the price is valid from (for block pricing)
'stock' => [
28 => 'product.stock.stocklevel',
29 => 'product.stock.warehouseid',
'catalog' => [
30 => 'catalog.list.typeid',
31 => 'catalog.code',
'media' => [
32 => 'media.url',
33 => 'media.preview',
Your file isn't imported at all because "product" is a domain, no price.typeid value.
And always use "....type" and their codes instead! IDs can change between environments but codes not.
