Custom data domain for Aimeos 20216
I was wondering if its possible create my own data domain. As a result I would be able to create my custom associate item for that domain and have access to in the expert mode of my admin.
-Thanks
-Thanks
Re: Custom data domain
Sure! The first step is to create the new data domain itself.
After you've created your own Aimeos extension (https://aimeos.org/developer/extensions/), you should set up the tables you need. Each table needs some default columns:
- id
- siteid
- ctime
- mtime
- editor
The tables can be automatically created during the setup phase if you create a setup task:
https://aimeos.org/docs/Developers/Library/Setup_tasks
The easiest way is to let Doctrine DBAL do the work. Then, it will also work with other database servers. Take the setup task in the ai-laravel extension as reference:
- https://github.com/aimeos/ai-laravel/bl ... aravel.php
- https://github.com/aimeos/ai-laravel/bl ... stomer.php
If you implemented that part and the tables are created when running aimeos:setup, we can continue to with the necessary item and manager.
- id
- siteid
- ctime
- mtime
- editor
The other question I have, is how you I add my own custom tab in the panel of expert data domain. This tab will linked to information that I have within the database.
- Expert Mode.JPG (95.09 KiB) Viewed 15526 times
You need to create the item/manager/controller first before you can add a tab for the new data domain.
Is this the right directory for the controller ; ext\ai-admin-extadm\controller\extjs\src\Controller ?
Yes, there are the ExtJS controllers of the core. The same structure exists in your own extension for the project and there you can store your own controllers.
I have made the item + Manager classes and made the extjs controller. What is the next step?
You need the code for the list and item UI as well as the item picker. Have a look at the tags implementation:
https://github.com/aimeos/ai-admin-exta ... /panel/tag
Afterwards, you also need the item pickers for the domains you want your items to associate to, e.g. for the product domain:
https://github.com/aimeos/ai-admin-exta ... ickerUi.js
I also did that. But the tab still hasn't appeared.
The last step is to add your new files to the manifest.jsb2 of your own extension like in the core:
https://github.com/aimeos/ai-admin-exta ... ifest.jsb2
